Page 58 of 112 FirstFirst ... 848565758596068108 ... LastLast
Results 571 to 580 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #571
    Nov 2014
    Bris, AU
    2720 -> 4120 with ease. Worked first go. Like a treat Thanks guys. Getting my hands on the latest Maps dvd tomorrow to load on. Going to go through and load up music tonight.
  2. #572
    Make sure you get Aussietigs POI database loaded on there too for speed cameras etc
  3. #573
    Sep 2014
    Greenslopes, QLD
    ^ this
    That POI db is great! I mostly use the speed/red light camera points, but there is so much more in there!
    .:R36 MY10.5::Wagon::Biscay Blue::Adaptive Dampers::Sunroof::Wheels:.
  4. #574
    Jan 2013
    Newstead, QLD
    Hi guys,
    Does anyone have firmware 6270 or the newer 6272??? I have a R model (C14) and it is very buggy and want to do a clean install. For some reason, I cannot find any links to getting it. What's the go, why is this not available anywhere?
    Any help would be much appreciated
  5. #575
    Because you need to wait for a factory install CD to be made available. If it's buggy go back to where you bought it from.
  6. #576
    Jan 2013
    Newstead, QLD
    Makes sense, thanks for the help
  7. #577
    Hi Guys, I was thinking about updating maps and firmware but after reading warning on 1st page about HW radio version 0003 am now a bit stumped!
    What would be the best firmware to use for the following specs (or should I risk it and try 4120)???
    Part number: 1T0035680C
    HW-Version: H04
    SW-Version: 2760
    HW Radio: 0003
    Active map: Aust+NZ
    Active map: Sensis
    Map version HDD: 7360
    Many thanks
  8. #578
    4020. Any higher could damage your radio tuner board permanently.
  9. #579
    Thankyou Sir Just downloading now from the link of the first page
    Is there any limitation on the map version I can use or will the latest version of maps combined with Aussietigs POI database be OK?
    Thanks again Kamold!
  10. #580
    No limit with maps or POIs, just firmware.
