Results 1 to 10 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
    Pacific Paradise QLD
    Did you put it in upside down Sounds like it
    Feb 2008
    Thanks for all the replies guys.
    I will try to use the recovery CD and see if it makes any difference. "finger crossed"
    2013 Jetta TSI Highline, Sunroof, Bi Xenon, GTI Pedals, Eibach (To be Installed)
    SOLD: Reflex Silver Jetta TFSI
    Sunroof, Leather, Charlston 18" Wheels, Neuspeed P-Flo, Full Neuspeed Carbon Fibre Engine Cover, GTI Pedals
    Feb 2008
    Hi Hillbilly,
    I put the disc in correctly. Somehow during the process, i think the process just stopped. I pressed eject disc and i think also Setup+Eject+*, then this happen. I now don't know what to do. Will try to manually remove the disc and try the recovery CD.
    Quote Originally Posted by hhlau2 View Post
    Hi Hillbilly,
    Turn the unit off and wait for a few minutes and turn it on again might clear it
    You will stuff it if you try and force it out as the carriage will be jammed and you cant just pull a disc out as it sits over a centre spindle which is held up under the disc to spin it.. You could try reset by holding in the two left buttons and the right hand one across the top all at once
