Page 43 of 112 FirstFirst ... 3341424344455393 ... LastLast
Results 421 to 430 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #421
    Pacific Paradise QLD
    Quote Originally Posted by David28 View Post
    Please help to clarify my query:
    I got a 2011 Passat with built-in Satnav RSN510 with version as below
    Part number: 1T0035680C
    Hw version: H50
    Sw version: 2840
    which reliable firmware version that I can upgrade without any re-coding, etc..? 4020 or 4120?
    Thanks
    4120 No recoding with any version Same version as my somewhat hopeless Satnav
  2. #422
    Dec 2013
    Act
    Thanks Hillbilly.
    Do you have any issue with 4120?
    Which 4120 image did you use? Is it the link in first page of this thread?
    Thanks
  3. #423
    Thanks Hillbilly.
    Thanks
    No issue with 4120 Just the unit as a whole yes that's the right one Burn it slow
  4. #424
    Dec 2013
    Parkside, South Australia
    Hi guys
    Thanks to the awesome instructions I was able to update my RNS510 successfully - VIM and everything working fine.
    My my only major problem is it appears that the Navigation DVD that came with my car is of such poor condition that when I insert it into the unit to reload my maps, it does not recognise the DVD at all. Tried to to burn a nice clean copy hoping that my laptop would have better luck, but no avail.
    This may be the wrong place to be discussing stairs particular issues, but what are my options to get my navigation back? Can I download the DVD! or grab a copy off someone in Adelaide? If all else fails, I might be able to drop into the local VW dealer and see if they have one I can borrow?
  5. #425
    Quote Originally Posted by wags View Post
    Hi guys
    Download the ISO from the link in reply 401 burn it slow and load that into the unit That's the version that most of us have used with success
  6. #426
    Dec 2013
    Thanks Hillbilly - apologies for not finding this myself - this thread goes all over the place!
  7. #427
    Dec 2013
    Hmmm - still the same problem....
    I have burned the DVD at 1x (apparently successfully). I start up the RNS510 and select MAP or NAV, and it requests the Navigation DVD. When I insert it - it thinks for a couple of second, and then requests the Navigation DVD again, this time with an audible voice request as well. There is an "OK" button with the message that you can click, but the system seems to sit doing nothing after that.....?
    Is it worth burning another copy of the Nav DVD? I'm hoping I haven't upgraded the firmware incorrectly and buggered the SatNav!
  8. #428
    If the firmware update finished correctly you haven't WHat map version is in it because it wont load a second copy of what you have .
    Eg got V5 need V6 Got V6 you don't need anything You can downgrade to V5 and then go back up to V6 but I found I couldn't reload the same version a second time.
    Tried when I was comparing the streets shown in the two versions. Otherwise go and see "Transporter" forum moderator who is in Adelaide
  9. #429
    After you insert the map DVD you should just hear it spinning, and the map should slowly load up the map picture of your location (because it is reading from slow DVD).
    In the background it will start copying the map data to HDD.
    If you hit the eject button you will get a warning message and also progress bar for the load.
  10. #430
    Dec 2013
    Kamold and Hillbilly
    Cheers for the advice. I can confirm that my burned DVD must have been no good because I went and caught up with a mate for lunch who worked at Solitaire (local dealership) and grabbed the V6 maps off him to upload. His DVD worked a treat in comparison to my burned one - all copied over in about 5 minutes and working perfectly.
    Thanks for all the help and suggestions - I was getting a bit worried for a second there!
