Page 97 of 112 FirstFirst ... 47879596979899107 ... LastLast
Results 961 to 970 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #961
    5238 is the most widely compatible version.
    Unless you have a specific reason to upgrade (ie some sort of issue with the unit) I would not bother going to 5270.
    You won't gain any features.
    Quote Originally Posted by dero View Post
    I wanted to get some confirmation before I set about trying to put an update to the 5274 version firmware.
    My current version info screen on the RNS510 shows:
    Delivery part number: 1T0 035 680 L
    HW-Version: H50
    SW-Version: 5238
    Reading from this link (Volkswagen RNS 510 Hardware and Software (firmware) Versions | my-gti.com)
    [/FONT][/COLOR]So that says to me that the available 5274 firmware is the most recent one available that it can be upgraded to. (Volkswagen RNS 510 Firmware Upgrade to version 5274 | my-gti.com)
    Is this correct?
    Also - the download shows that there's an option of a modified and unmodified firmware. What's the difference? Which is preferable to get?
  2. #962
    Jan 2015
    Brisbane, Queensland
    Ok thanks for that. I can live with that described known bug of 5238 where the map zoom changes on its own accord.
    Golf mk7 parts for sale.
  3. #963
    Jun 2018
    Hi guys,
    I'm new to this forum and to VW card and am wanting to update my RNS510 FW and maps. My car is a 2013 Scirocco R
    These are the details the secret menu give me -
    Delivery Port Number - 1T0035680L
    HW Version - H07
    SW Version - 5218
    Map Version HDD - 8035
    Can anyone tell me what files I'd need to update my unit? Thanks guys
  4. #964
    Pacific Paradise QLD
    Quote Originally Posted by JETMK3R View Post
    Hi guys,
    HW Version - H07
    SW Version - 5218
    5238 Go to the start of the thread its there along with instructions
  5. #965
    Jun 2018
    Thank you Sir
  6. #966
    Aug 2018
    SUburb
    Hi there. Anyone here who has firmware archive for VW Discover Pro MIB2? I am looking for version starting with SWDL_MHI2_ER_VWG or MHI2_ER_VWG. Thanks guys, help is much appreciated.
  7. #967
    May 2013
    Hi all,
    I followed the steps to update the firmware of my unit 1T0035680C, using the recommended version 5238.
    All good, 'SWL sucess' at the end. Then I checked the hidden menu and apparently the map is still there "Map version 8207". But when I tried to load the map, it doesn't appear on the screen. That's all right, because when updating the firmware it seems that the HDD is formatted and then all files is gone, including the map.
    I followed the steps to prepare the SD card with a map, using the map tool 3.0 and I burnt a DVD (that I have at hand) with the iso generated.
    Now what is intriguing me... Firstly I checked the SD card, there is less than 1GB in files, what is weird considering that the DVD used to upadate the maps is a double layer. So, why the SD has only 1GB? Secondly, I followed the steps... not turned on the ignition, insert the SD card on the radio, press both up right buttons together with Setup buttom and than insert the DVD to initiate the system to read the SD. When I did, after a while the double red lane screen appeared and it wasn't able to proceed. I had to insert the 're-boot CD' to have the system back.
    Am I missing something? The map file is corrupted/invalid? Is there anything in the installation of the map that I am doing wrong? The use of a DVD instead a CD maybe is the cause?
    Sorry for the long story.... any tip would be more than helpful.
    TIA
  8. #968
    Just load the map from the DVD.
    Why add unnecessary steps?
  9. #969
    May 2013
    I was overthinking... hahahaha
    Thank you!
  10. #970
    Aus maps are only around 700mb.
    The sdcard method is for western Europe maps which are much larger.
