Page 95 of 112 FirstFirst ... 45859394959697105 ... LastLast
Results 941 to 950 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #941
    File has been re-uploaded.
    The link should work now.
  2. #942
    Oct 2017
    Thank you so much you are a champion, I'm downloading now
    Do you know the file size or CRC? The first time I tried to download it only downloaded 63.6 MB (66,764,800 bytes) but it's up to 155 MB now so hopefully it'll get to the end this time, I'm just not sure how big it is ha ha!
  3. #943
    683MB or 717,029,376 bytes
  4. #944
    Sunshine coast
    Does anyone know where to source the latest maps now? JKU which previously sold them seems to be out of stock.
    132TSI Tiguan Allspace
  5. #945
    Oct 2017
    Thanks mate, just did the upgrade then, FYI the firmware upgrade is 683MB or 717,029,376 bytes and 7-zip tells me the CRC64 is: 86336C15CB76917E.
    The upgrade has successfully finished, my GPS initially thought I was in Germany which was a worry but after a drive it corrected the location (I was in my garage when I did the upgrade so it probably couldn't get a GPS signal initially I guess). The only issue I've noticed so far is that on the MFD on the cluster it doesn't show the GPS directions any more, is that something I can fix?
    I've got a 2012 Passat 118TSI; H/W version H70, came from S/W 4120 and maps 7492 to S/W 5238 and maps 8207.
  6. #946
    Pacific Paradise QLD
    Your local stealer Pun intended as about $300 or maybe more.
  7. #947
    Sep 2017
    Bondi Beach
    Hi. a little off the original topic in a way.
    does anyone know the name structure for AU firmware images from VW? Im stubbornly trying to get my MIB2 Discover Pro Retofit from EU to AU Firmware.
    my current Firmware starts as follows MHI2_ER_VWG11_ or SWDL_MHI2_ER_VWG11_ which is ER = Europe I guess. replacing with AU hasn't got me anywhere so far
    thanks all
  8. #948
    Quote Originally Posted by Evo* View Post
    thanks all
    It's not different firmware, we use the same as EU.
    There are multiple configuration settings which configure it as EU or au of which I'm not fully aware. Not sure if it's all just coding and adapation changes.
    Best bet would be to do a compare of a full adaptation channel map and coding of an AU delivered unit and change yours to match.
    Then load row2 maps.
  9. #949
    Sep 2017
    Bondi Beach
    Thanks for that info! I can stop looking for au firmware that doesn't exist haha.
    Well I have an old mib2high firmware. id like the most recent which I think is 814 maybe 815 to iron out some of the kinks. but I have no idea how to find this on the web. very very difficult to find any firmware online... I assume you're correct as from VCDS I can change these settings I know from my findings but the unit won't connect at 5F... My High2 unit was a pre CP removed (hacked) now non hacked because of firmware update...
    I got my VCDS cable today and had a poke at my non CarPlay MIB2 STD + Nav AU unit. I enabled Wifi Client and Hotspot as well as GEM menu plus a few more options for my DRLS etc very nicely. I can actually turn my DRL on and off from my Nav Screen =)
    When I tried to VCDS the MIB2High DP2 I have no success. Comm Status toys 3 times to connect. and get error "No response from Controller" So whatever they do to these pre CP removed units goes deep. (I lost all CP when I had to emergency format and load firmware) Does anyone know what can be blocking access to 5F on this unit?
  10. #950
    If it's been modified you need to first enter green engineering mode (hold down menu button) and then enable development mode for next X reboots.
    Then you will be able to access it via address 5F after it reboots.
