Page 93 of 112 FirstFirst ... 43839192939495103 ... LastLast
Results 921 to 930 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #921
    Pacific Paradise QLD
    No and sounds like low battery as that will cause whats happening
  2. #922
    Oct 2012
    Try putting in this string and saving, then go back and edit the coding bytes using long coding as appropriate for your car:
    04010000010000930011
    Mate, this worked and I was able to do one set of recoding, and now it won't change the code at all? It just comes up with "coding accepted" but when I go back to check the coding, the "current coding" refuses to change. Any ideas? ATM it's running as if it's got a sound system installed so low volume which is a bloody pain
    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
  3. #923
    There sounds like there is a bad eeprom in your unit.
    Initially it had no coding, now it's not saving new coding.
    I would try and enter the coding string a few times in a row to see if it will update, otherwise might need to look at a repair
  4. #924
    Oct 2012
    Got it to take the code by reinstalling firmware, coding that generic one you sent me, then recoding again. Fingers crossed its now bloody fixed!
  5. #925
    Good result
  6. #926
    May 2017
    Hi, do you know where I can have the rns510 updated here in Melbourne? There's a compatibility issue when i plug my Iphone ios 10.3 in MDI. Thanks
  7. #927
    Quote Originally Posted by RSanti View Post
    If you are using the cable that came with it you will find it will only charge it NOT play music through it.
  8. #928
    Aug 2017
    Hi everybody.
    Newbie here with little vw knowledge, however, my wife has a 2012 yeti with an rns510 that has decided that audio isn't nececary and that neither is English.......
    From what I have read, it isn't exactly an uncommon issue and is usually rectified with a software/firmware update, but there are so many hardware versions and software versions for different regions etc, I find it a little daunting.
    Anyone prepared to help me decipher exactly what I need to sort it?
    Thanks in advance
  9. #929
    Install version 5238
  10. #930
    Aug 2017
    Hw version says H60 and existing firmware is 3984.
    Will 5238 be compatible with the hardware?
    Also do you have a link to it.
    Thanks
