Page 91 of 112 FirstFirst ... 41818990919293101 ... LastLast
Results 901 to 910 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #901
    Oct 2012
    I would replace the gateway so that you can use current firmware.
    But that's me.
    You can get a gateway from online sellers that will have it already correctly coded for you if you don't want to use VCDS or OBDEleven etc to configure it.
    Thanks mate, I may go down that route at some point, although my gti is 07, so does that mean its a PITA to get to the CANBUS?
    And trying to figure out which CAN BUS i can get away with - would a 1K0 907 530 S be sufficient?
    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
  2. #902
    You can just get the newest 7N0 gateways they are probably cheapest.
    The location is a bit of a pain but once you know where it is probably only takes 15 minutes.
    Last time I did one I just took the bottom cover off the footwell, then removed the upper relay carrier to push it out of the way and you can then see the gateway up towards the firewall. It unclips and you can disconnect the cable.
    Some people come in from the engine bay by removing the rain tray but I think this would take longer.
  3. #903
    Oct 2012
    Thanks Kamold.
    So even with 1300 firmware, the RNS510 seems to be refusing to shut down. I have the multimeter sitting in line in the fuse plug and after a night locked and off, it is still drawing 1.88amps.
    Is there something I am missing? Perhaps coding of the old CANBUS H revision?
    Anyone got any ideas?
  4. #904
    First thing to do is upgrade the gateway, then you can run current firmware on your RNS.
    If you can find someone with access to ODIS-E (engineering) they can upgrade your gateway to software version 0178 which will resolve this.
    Otherwise you just need to physically replace the gateway with a new one that already has new software loaded on it.
  5. #905
    Oct 2012
    Gateway upgraded! $20 from the wrecker - told them it was a relay haha. Seems to have immediately solved battery drain!
  6. #906
    Quote Originally Posted by mb1907953 View Post
    Good result
    It is kind of a network relay...it's not a TOTAL fabrication...
  7. #907
    Oct 2012
    Hi Again Kamold,
    Going to call again on your expertise - I am trying to code the bloody thing and I keep getting Error 31: Request out of range. I have tried to change the coding from 9 bytes to 10 bytes, and then back, but it just wont accept either.
    Any other ideas?
  8. #908
    Trying to code the gateway?
    What is the pn and SW version on it?
    What exactly are you trying to change?
  9. #909
    Oct 2012
    Sorry - trying to code the RNS-510! Im trying to just code in the active speakers and change the display style to a different colour code (highline).
    It's currently coded as all zeros (00000000000000000000) and wont accept any code I put in!
    EDIT: Updated to 5238.
    HW04 unit
    1T0035680L is the part number coming up, although it was originally an A before update.
  10. #910
    Are you using a non-zero workshop code?
