Page 85 of 112 FirstFirst ... 3575838485868795 ... LastLast
Results 841 to 850 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #841
    Jul 2015
    Brisbane, Qld
    Hi Everyone.
    I've got a 2011 Passat CC and have just used the information and files located in this thread to upgrade my RNS 510 to a newer SW 5238 version.
    I bought a Australian V8 map on DVD from JKU on the Sunshine Coast so undated the maps while I was at it.
    All seems to have gone well as now I get the radio texts with the current song etc, can now see the hidden menu for showing what software i'm running and the video in motion is also working. It took about an hour to install and a few minutes driving around for the GPS to get a fix on me.
    However, I have noticed 1 item I think has changed for the worse.
    When reversing - the rear view camera shows on the screen, along with the top view of the CC on the left hand side for the OPS.
    The OPS is not completely transparent, there seems to be a grey fan shaped area where the orange and red lines show how close you are to an object. I'm sure before the upgrade it was totally transparent.
    Can anyone confirm ? Any ideas where I can find the information to make it transparent once again as it spoils the rear view camera picture as the view is now greyed out under the fan of the OPS ?
    Thanks
  2. #842
    They did change the OPS view and made it more granular for newer PDC controllers.
    It is more accurate as it now shows more radar increments.
    You can always close the OPS view and just see the RVC and listen to the PDC beeps if you prefer.
    There is no way to change the actual settings of the OPS view itself.
  3. #843
    Jul 2015
    Brisbane, Qld
    Thumbs up
    Thanks for the reply.
    I'll just have to get used to it, and as you said, minimize the OPS when the rear view camera is on if it is annoying me.
    May 2013
    Hi everyone,
    My RNS510 in my Tig has gained a corrupted boot screen (the image is all twisted and displays in out-of-alignment horizontal bands. I'm trying to fix it so it looks correct on start-up (thinking about selling the car) but I can't get to the ISO creation site any more (seems to have been taken down).
    Does anyone have a way to create the ISO so I can reload the original file?
    MY08 Mk5 GT Sport - sold
  5. #845
    Pacific Paradise QLD
    Quote Originally Posted by Mattlock View Post
    Hi everyone,
    A quick Google revealed this
    Volkswagen RNS 510 SWL Recovery CD for Gateway Error 202 or Boot Problems | my-gti.com
  6. #846
    May 2013
    Interesting, thanks. I attacked the googling from a different direction rather than thinking about recovery.
  7. #847
    Aug 2016
    NSW
    FW 5238 Upgrade & problems.
    I apologise upfront for a verbose post; but tried my best to be accurate & concise with the problem.
    Tiguan bought new 2009 (great car) in Penrith (Ver 2 Map). First problem to show up was F3 Wyong "Black Hole" - system crashed, then after a few minutes, rebooted. Dealer told me problem was I lost a satellite at that point!!
    Took it back again after next occurrance to service manager this time; Dealer returned the vehicle after having it all day, "fixed"; but nothing changed. Tried reloading the Ver 2 map myself only to get "CD/DVD ERROR"!
    So in frustration just lived with the problem.
    Then, bought Ver 7 Map from Dealer when it came out, thinking it was a programming problem in Ver 2 Map: only to be greeted with the same error message!
    Thinking then it might be a FW problem, came across this tread after much searching (Google search) & followed Kamold's notes exactly to upgrade, which seem to work a treat (many thanks).
    Tried loading Ver 7 maps again.....same error message splashed the screen!!
    Decided then the DVD optical reader must be at fault - no problems reading CD's; just won't load DVD''s.
    BUT THEN; if that was the case, why did the DVD work successfully with the FW upgrade?
    Anyway, decided to replace the DVD; purchased online from cars-equipment.com (cz);
    ORIGINAL DVD
    NEW DVD
    After installing the new DVD & switching the unit on, without inserting the key, the very first screen splash appeared with :
    "Loading CD/DVD Please wait...."!! I hadn't put a DVD near the thing!
    This was then followed with the next one "CD/DVD ERROR". I tried inserting a CD into the machine, but it was locked closed. So that just seemed a big waste of money!!
    So after all this I've just put the old DVD back in - at least it "half works"; but still no maps installed.
    The only thing it seems is to copy (?) the Ver 7 map onto an SD card & install it from there?
    Extremely frustrating to say the least. Just hoping someone might be able to shed some light on the problem what I'm doing wrong.
    ANY advise would be greatly appreciated...
    Attached Thumbnails Attached Thumbnails Firmware updates for RNS510 units in Australia/NZ-rns-510-jpg   Firmware updates for RNS510 units in Australia/NZ-loaded-fw-5238-jpg
    Firmware updates for RNS510 units in Australia/NZ-original-dvd-jpg   Firmware updates for RNS510 units in Australia/NZ-new-dvd-jpg
  8. #848
    There is a utility available to load Maps from SD card online somewhere though I've never used it.
    If you are in Sydney happy to take a look at it for you some time.
  9. #849
    I have found that you cant reinstall the same version map over itself EG 7 over 7. You can load 6 over it and then 7 but not the same one.
    Was that unit new in the car or an EBay special????.
    Also best to use a DVD burned as slow as possible if a copy.
  10. #850
    Aug 2016
    NSW
    Many thanks Kamold; think I remember seeing it on the "Christian-jeanin" website - link from this site.
    Many thanks for the advice Hillbilly - (not a Ebay job - a $3k optional accessory included when bought new!!) - thats what makes it more painful....!!
