Page 8 of 112 FirstFirst ... 6789101858108 ... LastLast
Results 71 to 80 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #71
    No problem, good luck with getting your poi database setup.
    Ps thanks for bailing Europe out of its debt problems
  2. #72
    Apr 2012
    Germany
    you guys helped me, so it alteast what i can do
    i found somewhere its could be the databas name, so i am gonna try to reset it,
    and get back with the result to help others
  3. #73
    Mindarie, Perth (WA)
    kamold,
    I've found a 4020 version which may be suitable for A version units.
    Currently downloading it and will attempt to apply it this weekend.
    Any chance (if I can get it working on mine) that you can re-organise the partition profile to reflect 90/5/5%?
  4. #74
    Yeah I saw that they have done the table swap for 4020 as well.
    By all means test it but to be honest I don't know if its worth the trouble...
    There are no new features at 402x and haven't really noticed any speed increases as advertised. However it would be worth changing the partition scheme so that you can swap between versions without losing your maps and music.
    JohnC has the cable at the moment so he'll have to write the Dlscript.txt file for you for integrate into the firmware image. He's a busy man but he is always very obliging with requests.
  5. #75
    Apr 2012
    doonside sydney
    Hi all i am having a problem saving music from a CD to the HDD on RNS510 satnav. service center said it is right protected. i have tried making a CD through itunes and media player no luck. they play on the unit no problems any tips thanks. its a new tiguan pacific only two weeks old
  6. #76
    Apr 2010
    You can copy MP3 and WMA files from a CD/DVD to the HDD, but you can't rip an audio CD to it.
  7. #77
    Apr 2012
    doonside sydney
    Thanks for that Ryan_R
    ---------- Post added at 08:12 PM ---------- Previous post was at 05:26 PM ----------
    it works !!! made a disc in MP3 format they all went across to the HDD. well pleased
  8. #78
    Oct 2011
    FLYNN, ACT
    H Guys,
    VW installed a new RNS in place of the MFD2 in my 07 Jetta. Details are:
    Part No: IT0035680C
    HW Version: H52
    SW Version: 2840
    Map Version: 7679
    HDD: Partitions: 3
    Therefore, from this forum, I understand that I have a "C" version with 2840 firmware and Version 5 Map Data; is that correct?
    I would like to update the firmware to 3810 at least and have a CD image disk ready to go. However, my RNS radio when running on battery times out after 30 mins (this is covered on page 6 or so of the RNS booklet in the car's manual.
    Will this timing out interfere with a firmware upgrade?
    All help appreciated, Roger.
  9. #79
    Jun 2009
    Western Sydney
    That timing issue won't be a problem when installing the firmware. That's time out is normal and only occurs when nothing is actually happening. You should make sure the battery has a decent charge on it before starting. It can take around an hour to run the updates in some instances. If it dies mid FW install, you will have problems. If you have a charger, connect it while doing to install to ensure that it won't be a problem.
    Is there a reason you only want to install 3810 over 4020?
  10. #80
    Oct 2011
    FLYNN, ACT
    Thanks John,
    I got the impression from several VW forums that upgrades need to be done incrementaly, ie, 2xxx - 3xxx - 4xxx, or HDD partitioning became an issue. My 510 doesn't have a Personal poi capability and that is what I am after.
