Page 64 of 112 FirstFirst ... 1454626364656674 ... LastLast
Results 631 to 640 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #631
    Quote Originally Posted by Felixrising View Post
    Just wanted to send kudos to kamold... Thanks for all your support and contributiona here. 5238 is working a charm in my unit, subjectively it feels more responsive and there are many small changes to menus, more than I've seen documented elsewhere.
    If I've helped you, buy someone a beer.
    Ideally me but if we never meet, pay it forward anyway.
  2. #632
    Pacific Paradise QLD
    Quote Originally Posted by dero View Post
    Cheers. Thank you very much.
    Bit of a pain that the VW service centre isn't able to do the update of firmware for me when they have the car for servicing for the day. I'll get the firmware and POI data downloaded and organise a copy of the maps to come to me then. You've been a great help.
    They wont do what you get here as its modified firmware Thanks to Kamold.
    VW will only update it if there is a problem with the unit and even then it wont be the same as this.
    You will have to buy the maps no copies on here.
    You unit will be later than mine and it was a C with 04
  3. #633
    Jan 2015
    Brisbane, Queensland
    Aah thanks - I didn't realise that the firmware was modified.
    Maps- I've put a purchase through so hopefully that will come through relatively soon. I'll get everything downloaded in readiness for the weekend when I have the time to get the update process occurring.
    Paying it forward... already did that last night - with some really smooth grandfather port!
  4. #634
    Dec 2009
    Noosa, QLD, Australia
    Thanks, once again, for your great work, Kamold. Made my day.
    Golf MY11 GTD | Candy White | 5-door | DSG | ACC | RNS-510 | Park Assist
  5. #635
    Jan 2015
    Next question. I've downloaded and successfully flashed the newer firmware into my RNS-510. The mapping data disc I bought from JKU came and on following the instructions, it doesn't seem to do all that much after loading in the disc.
    The system flashes up with a box saying that a navigation/mapping disc inserted and then doesn't do much from there. Is there something I'm meant to do so that the mapping data is copied into the system?
  6. #636
    It should take about 15 mins to load the map and once it starts if you press eject a warning will come up telling you not to.
    Cant remember if you have to do anything once you put the disk in.
    You should hear the internal mechanism working as it reads the disk
  7. #637
    Jan 2015
    You should here the internal mechanism working as it reads the disk
    Ok cheers. I'll try that again now and see how I go. Report back when I've got it done whichever way it comes out to be.
  8. #638
    You don't have to do anything. As hillbilly mentioned, if you press eject during the install process it will give you a warning and a progress bar. If you didn't see this it has already installed the maps.
  9. #639
    You might have to go for a drive to let the unit get its actual location in the world It could take a couple of kms
    Once when we updated the firmware we initially only got a "base" map and had to go for a drive for it all to come right
  10. #640
    Yes this can take anywhere up to 30mins. Usually much less.
