Its not the no DAB that is the issue.
Older radio boards use a different flash chip which is more susceptible to premature death by flashing.
Can be done at your own risk
please confirm. You have a 1T0 035 680 B HW004 with radio board 0003, and its successfully running 5238? So no dab isn't a show stopper?
.:R36 MY10.5::Wagon::Biscay Blue::Adaptive Dampers::Sunroof::Wheels:.
Yes I can confirm that I have a 1T0 035 680 B HW004 with radio board 0003, and its successfully running 5238. It loaded fine and everything is working including RDS.
I have a 2011 B7 Passat.
The RNS510 doesn't show in the secret menu its firmware version. Only shows the AM/FM radio manager settings. I don't have a cable to interrogate the computer so I'm guessing the only way I can see what firmware version the unit is sitting on is to open the thing up and look at the sticker.
Question though is, how? How do I get about getting at the unit? Is there a guide showing me potentially what tools I'll need which will let me get the covering surround off without damaging the clips so I can unscrew and look at the sticker?
Download 4020 and try it My mid 2010 had 2860 or similar It now has 4120.
You need a set of these to remove panels VW Audi BMW Nissan Ford Honda Interior Trim Clip Removal PRY Tool KIT Radio Dash | eBay
Cheers - thank you very much - I'll get a set of those tools.
Is there some sort of guide or an image where I can reference to see where the clips sit and how it is to be used?
Don't really need trim tools to get the head unit surround off. Just pry off with your fingers under the bottom edge.
Then you have 4 T20 Torx screws.
But I wouldn't bother with any of that.
Your unit if factory fitted will be running 2760.
Just load 4120.
're Zheino SSD...
Any idea what controller it uses? I noted it uses MLC NAND ... So longevity might be an issue depending on wear levelling and controller managment of reserve cells/space. I couldn't find any reviews. I had considered using an IDE SD card adaptor with a extreme pro or similar card using SLC flash... But it's slightly more expensive option and untested in this application afaik.
Unless you're deleting and reloading music every day I don't think cell endurance is really going to be an issue.
If the drive dies, just replace it...its not like it costs much.
Otherwise stick to the overpriced Hitachi spinning disk.
