Page 60 of 112 FirstFirst ... 1050585960616270110 ... LastLast
Results 591 to 600 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #591
    Sep 2014
    Capalaba, QLD
    Hi,
    I need some assistance with my unit, I have an RNS510 - 1TO 035 680 B with H04, I'm just in the process of putting new HDD in and want to know what is the correct firmware and where to get it. I was hoping to have RDS as I have it now with my RCD510...is this possible.
    Thanks Simon
  2. #592
    Pacific Paradise QLD
    Quote Originally Posted by Sim T5 View Post
    Hi,
    Thanks Simon
    From the first post in this thread the links are there for each version Read it carefully
  3. #593
    Sep 2014
    Capalaba, QLD
    I did download 38xx for the "B" version but this firmware does not have RDS which as far as I'm aware is possible on these units, also this version is a European version which means the DVD gives a region error. I was hoping there was another version around that would fix these issues....
  4. #594
    Wait for Kamold to answer He will know. I think RDS is only available with 4xxxx firmware but I could be wrong
  5. #595
    RDS is available from 4120 onwards. DVD region can be set with vcds.
  6. #596
    Sep 2014
    Capalaba, QLD
    will 4120 work with my unit which is a B HW04?
  7. #597
    It's the hw radio version which you need to check.
  8. #598
    Sep 2014
    Capalaba, QLD
    I have already pulled the unit apart, is it possible to get this without the unit being on? or do I need to check in the menu?
    Thanks Simon
  9. #599
    No, you need to get it from the menu
  10. #600
    Sep 2014
    Capalaba, QLD
    thanks for all the help Kamold, I have put the unit back together with the old drive and made the HDD removable without stripping the unit by folding the two tabs up....seems to be quite secure just with the top screw...when I get the SSD drive later this week I can easily fit it. I have just reloaded the old drive with 3970, 90-5-5 partition. This current drive keeps failing which is why I'm going to a SSD...the HW Radio is 0003
