Page 55 of 112 FirstFirst ... 545535455565765105 ... LastLast
Results 541 to 550 of 1116
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #541
    Pacific Paradise QLD
    Quote Originally Posted by shane_in_oz View Post
    did the software update seems all good. I tried loading the ver 6 au maps hat I have but it is not being recognized by the head unit. does it need to be the original disc as I never got one with the car.
    thanks
    You cannot load the same version map over the top of itself Have a look for a V5 and load that then update to what you had Other option is to spend $55 and buy V7.
    Please don't ask on here for a copy.
  2. #542
    Feb 2013
    Mortdale, NSW
    All working perfect now thank the info hillbilly
  3. #543
    Sep 2014
    Greenslopes, QLD
    It looks like there are a few newer versions of firmware that in OP. However h/w compatibility is questionable. For instance, the 5269 and other 52xx have a comment "All D and later versions", my RNS510 is the 1T0035680C, so it would appear I'm right out of luck.
    But wait! There's more. This firmware list mentions my version as being supported with a "modified version" of 5269... well, that is cryptic enough for me to avoid and let someone else experiment. Does anyone know what this is about?... original thread in german (I speak german btw). I'll keep digging.
    UPDATE: Looks like this modified firmware is the way to go.
    http://gpsunderground.com/forum/volkswagen-seat-skoda/20308-all-available-firmware-rns510-45.html
    .:R36 MY10.5::Wagon::Biscay Blue::Adaptive Dampers::Sunroof::Wheels:.
  4. #544
    Quote Originally Posted by Felixrising View Post
    Put 4120 in and be happy Mine is a C and it works as well as anything VW can There isnt really any advantage going to anything else.
    Euro versions are different due to the size of partition required for the larger maps.
    Also some of the higher numbered versions are for units with DAB boards and you can stuff an older unit if you load it, be warned
  5. #545
    Sep 2014
    Greenslopes, QLD
    Yes, I installed 4120 last night, no issues - despite many reports of needing to recode when flashing 4120 on other threads... The newer 52xx stuff is reportedly faster...
    • Voice Control (requires microphone – see Volkswagen RNS 510 Microphone Connection for voice control)
    • NEW DAB+ Support (from 5xxx)
    • NEW DAB Support (from 4xxx)
    • NEW Radio Text (from 4xxx)
    • NEW Faster navigation and user interface
    • NEW Automatic illumination control
    • NEW Enhanced destination input
    • NEW hold down the setup button for 30 seconds and get the following menus: FM, AM and the new VERSION INFO (map version and type, hw and sw versions)
    • NEW Compass
    • NEW POI- see Volkswagen RNS 510 Maps POI – New Features with firmware 3xxx
    • NEW Languages – Arabic, Russian, Turkish and Polish
    • Speed Limit Display
    • Stability Improvements
    • Faster Startup (from 2720 onwards)
    • Display OPS and RVC at the same time
    • SDHC 32 GB Support (HW04 and above)
    • Display Off on extras tab
    • Climatronic control if approriate climatronic fitted
    • Clock display if RNS 510 swtiched off
    • Excluded roads (under route options)
    • GPS coordinates entry
    • Additional adjustments for video
    • Larger RVC screen with transparent menus at the side
    For the moment, I'll stick with 4120 as per your suggestion... thanks.
    5238 modified is here: All available Firmware for RNS510 - Page 45
  6. #546
    As you see from what you have posted it supports DAB and DAB+. Also that forum page 45 link is a European one and the partitions on the HDD for modified firmware is totally different
    If you load it in an unit without a DAB board you run a very good chance of bricking it.
    Thats why most of us dont use it.
    Have never had to recode ever in several incremental upgrades
    Your choice however.
  7. #547
    Sep 2014
    Greenslopes, QLD
    Yes, the model number must match... Mine is the 1T0035680D, 680 is the Australia/NZ version, so I wouldn't touch it unless the version matches the description. There are a few people who asked the question regarding this specific version and some answers saying, you can do it anyway... I'll PM them to ask how they fared.
    Last edited by Felixrising; 27-09-2014 at 07:09 PM. Reason: updated model - mine is a D not a C
  8. #548
    I have been testing 5238 for some time.
    No enhancements or changes worth mentioning.
    If you simply MUST have later firmware on your unit because you like to fistpump every time you upgrade and don't brick you unit, PM and I will send you a link with firmware modified for Aus.
    Otherwise stick with 4120 as you won't notice anything. This is why I haven't made it available. Risk for no reward.
  9. #549
    Does it seem more responsive?
    Any idea what the 'Automatic illumination control' is, compass worth mentioning?
    MK6 CS GTI
  10. #550
    No. These features are from earlier updates.
    The list is like a complete changelog since initial release, not the current version.
    Compass has been in there since 2600 firmware, auto dimming perhaps even earlier.
