I couldnt get that link to open This one does Firmware updates for RNS510 units in Australia/NZ Go to the Firmware 412x - Link and click on it
Hi Rick
Have a look in Post #2 here: http://www.vwwatercooled.com.au/foru...dex-65460.html
Keep in mind that some of the newer firmware CDs erase the coding of the RNS510 so you should back that up with VCDS first and then restore the coding after the upgrade.
POI's need to be stored in the correct folder location (PersonalPOI) at the root (top level) of the SD card.
Link works ok for me...
It's the **LOOK HERE FIRST** Important Threads & Stickie Index thread in this subforum
Ah those links, gotcha. I've had to restore coding when upgrading to one certain firmware. kamold may have since edited the ISO so that it's no longer a problem. Whoever uploaded it must've [re]moved it.
I was never able to get that ISO to work in may car. Must have burnt it to about 10 different types/brands of disc, and never had any luck. I've always been able to burn maps without an issue, so not sure if it is that FW4120 ISO that had issue? If someone has a a disc that they know works in their car, it'd be great if they could send it to me!!
Thanks for the info, will do some reading and have a crack over the weekend...wish me luck hope I don't wreck my unit.... will let you know how I go
Hi guys, so have had a quick read at the link provided by Ryan. As I don't have a cable is it best to stick with firmware 4020 so I don't have to recode the unit?
Use 4120 I have never recoded it ever and have done incremental upgrades without problems You need to have a C unit or higher for that version
thanks Hillbilly, so I don't screw this right up.. My unit is an original B version.. the part number changed when I upgraded to v3810 to 1t0035680D. will 4120 work with this without recoding?
