Page 48 of 97 FirstFirst ... 38464748495058 ... LastLast
Results 471 to 480 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
    Sep 2014
    Capalaba, QLD
    So I tried to roll the dice with 4120 but I get SWL Error. I have tried burning it again but same issue which I don't get with the older 3xx. I assume the radio wont allow it or the iso I have is no good....
    Radio won't stop you. Just can't read the CD.
    Sep 2014
    Capalaba, QLD
    Ive tried another fresh download and burnt it the same as the other software that works fine and still get the same error.
    Pacific Paradise QLD
    Burn it on a DVD with imgburn at no more than 4 speed
    Sep 2014
    Capalaba, QLD
    So thanks to the link Kamold sent me I downloaded 5238, it loaded fine and tested ok and I now have RDS....getting the coding done tomorrow so I'm very happy with the outcome. Thanks for every ones help....
    Sep 2014
    Greenslopes, QLD
    please confirm. You have a 1T0 035 680 B HW004 with radio board 0003, and its successfully running 5238? So no dab isn't a show stopper?
    .:R36 MY10.5::Wagon::Biscay Blue::Adaptive Dampers::Sunroof::Wheels:.
    Its not the no DAB that is the issue.
    Older radio boards use a different flash chip which is more susceptible to premature death by flashing.
    Can be done at your own risk
    Sep 2014
    Capalaba, QLD
    Yes I can confirm that I have a 1T0 035 680 B HW004 with radio board 0003, and its successfully running 5238. It loaded fine and everything is working including RDS.
    Jan 2015
    Brisbane, Queensland
    I have a 2011 B7 Passat.
    The RNS510 doesn't show in the secret menu its firmware version. Only shows the AM/FM radio manager settings. I don't have a cable to interrogate the computer so I'm guessing the only way I can see what firmware version the unit is sitting on is to open the thing up and look at the sticker.
    Question though is, how? How do I get about getting at the unit? Is there a guide showing me potentially what tools I'll need which will let me get the covering surround off without damaging the clips so I can unscrew and look at the sticker?
    Quote Originally Posted by dero View Post
    Download 4020 and try it My mid 2010 had 2860 or similar It now has 4120.
    You need a set of these to remove panels VW Audi BMW Nissan Ford Honda Interior Trim Clip Removal PRY Tool KIT Radio Dash | eBay
