Page 47 of 112 FirstFirst ... 3745464748495797 ... LastLast
Results 461 to 470 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #461
    Feb 2008
    I forgot to mentioned that the dvd still stuck inside the unit and i have tried everything but couldn't get it out.
    Cheers,
    Heng
    2013 Jetta TSI Highline, Sunroof, Bi Xenon, GTI Pedals, Eibach (To be Installed)
    SOLD: Reflex Silver Jetta TFSI
    Sunroof, Leather, Charlston 18" Wheels, Neuspeed P-Flo, Full Neuspeed Carbon Fibre Engine Cover, GTI Pedals
  2. #462
    Doesn't sound too good.
    You'd have to take the DVD drive out and remove the disk, put in the recovery CD and then try to resurrect it.
  3. #463
    Pacific Paradise QLD
    Did you put it in upside down Sounds like it
  4. #464
    Feb 2008
    Thanks for all the replies guys.
    I will try to use the recovery CD and see if it makes any difference. "finger crossed"
  5. #465
    Feb 2008
    Hi Hillbilly,
    I put the disc in correctly. Somehow during the process, i think the process just stopped. I pressed eject disc and i think also Setup+Eject+*, then this happen. I now don't know what to do. Will try to manually remove the disc and try the recovery CD.
  6. #466
    Quote Originally Posted by hhlau2 View Post
    Hi Hillbilly,
    Turn the unit off and wait for a few minutes and turn it on again might clear it
    You will stuff it if you try and force it out as the carriage will be jammed and you cant just pull a disc out as it sits over a centre spindle which is held up under the disc to spin it.. You could try reset by holding in the two left buttons and the right hand one across the top all at once
  7. #467
    Apr 2010
    I know the 3 button-combo along the top of the HU is used to reset the device during normal operation, but I recall you need a different combo of buttons for when you're in the firmware upgrade mode, and I'm sure one of those buttons in the SETUP key.
    Try <SETUP>+<EJECT>+<MIC> to enter downgrade mode....
    http://www.vwgolf.net.au/showthread....will-not-start
  8. #468
    Feb 2008
    I have tried all combo, SETUP+EJECT+*, <+>+* but the unit still stay in the white screen.
    I have also tried disconnect the power to the unit and connect again after 60min but it still the same white screen.
    If i should not tried to force the CD out, i just don't know what other way I can eject the CD and put the recovery CD in.
  9. #469
    RNS 510 will not start
    Was just trying to reset it to help him get the stuck DVD out Not anything else where is the Mic key
  10. #470
    Apr 2010
    Some unites have a mic button top-right, others have a star, and there may even be another variant.
