Page 42 of 97 FirstFirst ... 3240414243445292 ... LastLast
Results 411 to 420 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
    Sep 2014
    Greenslopes, QLD
    Yes, the model number must match... Mine is the 1T0035680D, 680 is the Australia/NZ version, so I wouldn't touch it unless the version matches the description. There are a few people who asked the question regarding this specific version and some answers saying, you can do it anyway... I'll PM them to ask how they fared.
    Last edited by Felixrising; 27-09-2014 at 07:09 PM. Reason: updated model - mine is a D not a C
    .:R36 MY10.5::Wagon::Biscay Blue::Adaptive Dampers::Sunroof::Wheels:.
    I have been testing 5238 for some time.
    No enhancements or changes worth mentioning.
    If you simply MUST have later firmware on your unit because you like to fistpump every time you upgrade and don't brick you unit, PM and I will send you a link with firmware modified for Aus.
    Otherwise stick with 4120 as you won't notice anything. This is why I haven't made it available. Risk for no reward.
    Does it seem more responsive?
    Any idea what the 'Automatic illumination control' is, compass worth mentioning?
    MK6 CS GTI
    Jun 2014
    Manly, NSW
    Hi,
    Im a noob to VW and this radio but I'm interested in seeing what's available in terms of firmware update.
    I have a 2013 Multivan and it came with a radio:
    delivery part number 7F0035680B.
    HW Version H09
    SW Version 5238
    australia NZ
    sensis
    Map HDD 7679
    Is this the latest? And if not, where do I find update info for the latest version for my radio,
    many thanks
    Matt
    Pacific Paradise QLD
    Quote Originally Posted by psionic001 View Post
    Hi,
    HW Version H09
    SW Version 5238
    australia NZ
    sensis
    Map HDD 7679
    many thanks
    Matt
    Its got as late as you need most only use 4120 and its a bit more than just a "Radio"
    Yours has a different model number to most RNS models so 5238 probably is latest
    Latest map is 7920 or V7 available at your friendly Stealer for about $55
    No. These features are from earlier updates.
    The list is like a complete changelog since initial release, not the current version.
    Compass has been in there since 2600 firmware, auto dimming perhaps even earlier.
    Sep 2014
    Greenslopes, QLD
    I was just poking around and noticed the HWDAB field populated... 255 looks like 11111111 in binary, which I guess could mean nothing present or something present... No idea... What does yours show?
    Also, I was copying some music from a music folder on sdcard to hdd, but I noticed after copying that it seems to have eliminated the music folder and moved the album folders to the root of the hdd... Is this typical or did I miss something along the way... How else do you do a bulk import?
    Also, I saw somewhere that rev D onwards (C10/C11/C12) supports bigger 2TB SDXC cards... but no support in software it would seem.. FAT64/exFAT seems to be missing I guess.
    Quote Originally Posted by Felixrising View Post
    If you read through the thread (Its a good idea) I think in one of Kamolds posts he said the 255 means IT DOESNT HAVE DAB
    From GTI Forum
    The version tested to work here in Australia is the 1T0035686C (1T0 035 686 C) with a Hardware Level of HW:09 and running software level 5238. This unit is a stock RNS 510 with LED screen, 40GB hard drive and is the latest available model from Volkswagen.
    Only the above has DAB C and a D most definitely DONT. Mine is a C and when you put the 4120 in it changes to appear as a D but in fact is still a C Its all in the thread if you care to read it
    I have a 40g HDD and a 32g SD card and I just play the music off that because it took 2 hours for the HDD to load about 10G of music in MP3 Format. It loaded each track one at a time and took a long time to do each one They are all in the root directory, about 3500 of them
    Sep 2014
    Greenslopes, QLD
    You're right, I ought to use that search function
    I wasn't going to leave a SD in there, but I'm thinking it might just be a good idea after all
    You dont need to search just start on page 1 and work through it Thats how we have learnt, Its all there.
    Same questions all the time when its all there already.
