Page 41 of 112 FirstFirst ... 3139404142435191 ... LastLast
Results 401 to 410 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #401
    Pacific Paradise QLD
    Quote Originally Posted by Mikkaa View Post
    hi Hillbilly, sorry to be a pain. it appears the link is dead.
    Try this https://docs.google.com/file/d/0B3Cr...it?usp=sharing It comes up for me this time
  2. #402
    Thanks Hillbilly, DL'ing now.
  3. #403
    Don't bother upgrading firmware yet as you'll have to reload after replacing the HDD...
  4. #404
    Oct 2013
    kerkrade
    hallo,
    I did instal Firmware 412x - Link
    However I did not sow the note that hv version must be higher than 3.
    my is wel 3 and now i am having some problem that my power battery from the car is every day empty.
    is there any solution to fix it. I did disconet my rns510 from the car. there is some information about rns510 in attachment. please anyone help.
    Attached Thumbnails Attached Thumbnails Firmware updates for RNS510 units in Australia/NZ-2013-10-05-10-57-00-jpg
  5. #405
    Quote Originally Posted by zeca View Post
    hallo,
    Did you install the European version as the 4120 for Australia partitions the HDD differently and it wont then load a euro map as the partition is too small
    By the link you have listed it appears you have the wrong firmware version if as it seems you are in Europe I see from your Newbies post you are in Holland so this will be the wrong version I would think. Someone may be able to point you to where you can get the correct Euro version
  6. #406
    Oct 2013
    kerkrade
    hi,
    Yes it is Europian version. I did post wrong one (copy past fout). and also i see that i am on the wrong topic. By the way thank for quick replay and i ll try to find a right topic without posting new one
  7. #407
  8. #408
    Oct 2013
    kerkrade
    thanks a lot
  9. #409
    Ballarat, Vic
    Thanks for the great write up, detailed instuctions and the .iso. My unit is now running the latest firmware and seems a little snappier, also loving the custom boot screen I got on there.
    Easy as pie to do this update, cheers to all involved.
  10. #410
    Aug 2011
    vic
    Question... have there been any updates since the 4020 release? I feel like I have been on this version for a lot longer than the time spent between other versions..
