Page 34 of 112 FirstFirst ... 2432333435364484 ... LastLast
Results 331 to 340 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #331
    Jul 2010
    Quote Originally Posted by omega31 View Post
    As the Car is new I will request the Dealer to check it next week.
    I can confirm that dealer will replace battery under warranty if it's not holding charge.
    Into my 3rd year and just had mine replaced.
    Would be a good issue to raise for anyone coming into your last year of warranty.
    MY11 Tiguan 147TSI (SOLD)
  2. #332
    Feb 2013
    VIC
    Quote Originally Posted by aussietig View Post
    Dealer Confirmed the Battery was finished and replaced with a new one. I can confirm your confirmation.
  3. #333
    Re: Firmware updates for RNS510 units in Australia/NZ
    Good result.
  4. #334
    Melbourne, Vic
    Turn unit on Hold SETUP down till screen changes to the two radio bands and Version information
    Press that and it will go to black and white screen and will tell you on one line
    SW version XXXX Thats the Firmware
    Further down it will say MAP version XXXX
    Now you know
    You can only update so far in the Firmware on that unit as per the Sticky but can update to the latest map
    My RNS510 says
    Part No 3T0 035 680 G
    HW H07
    SW - 5128
    Map version DVD 7920
    I dont have any further information in the version information option.
    The question I have is, I would like to FW update and add VIM. I would also like to activate TV and I have heard I can also get DAB or DAB+?
    Should I be looking at VCDS changes for these options? I dont want to downgrade the FW to get VIM, but I am more interested in DVB TV anyway, even if only when stopped.
    I have voice control of Nav, female and male voice guidance, speed advisory, (although it says 120km/h between the Westgate bridge and the Ring road in Melbourne, and that is definitely 100km/h with 2 x fixed speed cameras). I have the original V5 DVD of the maps, but got a V6 version of maps recently.
    I cant interrogate with VCDS right now as I need a new cable with CAN-BUS. This is on its way though.
    2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
    2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
    2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
    2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
  5. #335
    Pacific Paradise QLD
    Quote Originally Posted by spud75 View Post
    My RNS510 says
    HW H07
    SW - 5128
    Well Kamold will confirm or deny this but according to the threads There is NO RNS510 that can get either DAB or TV
    This is because it doesnt have either a TV tuner or a Dab radio board as well as Aussie using Dab+ which is different to other parts of the world Read post 254 and onward about this and page 24 here
    New firmware for RNS510/Columbus versions 4120 and 5210
    Get VIM on its own here which of course is illegal in Australia if the driver can see it .
    2012 My13 147 RNS510 VIM - Up and running
    BY the look of yours it is fully updated anyway Most of us only use 4120. The facilities in the Nav are in the hardware or firmware and dont think a cable will do much I could of course be wrong
  6. #336
    My RNS510 says
    HW H07
    SW - 5128
    There is currently no DAB tuner capable board in an RNS510 available for Australia. This may (likely may not) change. My guess is that VW Au will simply wait for the new unit to be released with the Mk7 Golf to support this feature and leave the rest of us behind.
    Yes you can enable VIM by loading the Berto-VIM or similar firmware hack CD.
    In order to add DVB-T you will need to add a third-party external interface such as this. I have not used this or any other such interface personally.
    As Hillbilly mentioned we use slightly different versions of the DAB protocol set (DAB+) so you would need to check with the manufacturer of any media add-on to validate if their receiver supports DAB+ stations. In most cases its a firmware update that is all that differentiates being able to receive the DAB+ stations however best to confirm prior to purchasing.
    There were multiple potential products set to hit the AU market towards the beginning of LAST year to bring an external DAB+ interface to VW head units however the all appear to have disappeared....not sure what that means
    The easier option it would seem these days is to stream audio from your internet radio source of choice (eg Pandora, Rdio etc) to your headunit over A2DP to your Bluetooth unit.
  7. #337
    Melbourne, Vic
    Thankyou, kamold and hillbilly. Guess that ends dimple DVB on the rns without an external tuner.
    I must sppologise about the 120km speed advisory. I was halfway through the update from v5 to v6 maps. V5 has speed advisory at 120km, v6 seems to be much better.
  8. #338
    Jan 2013
    Hi,
    I tried to check the firmware version of my RNS510, but after pressing the Setup button and holding it only the FM and AM buttons came up in the service menu, no version button.
    Does it mean I have a very old firmware, right? Which fw version would be safe for me?
    MY18 VW Tiguan Comfortline
  9. #339
    Quote Originally Posted by PeteC View Post
    Hi,
    Should come up with AM FM and Version information on all of them
  10. #340
    Jan 2013
    For me it doesn't come up. I tried with the ignition on and without the key too.
