Page 30 of 112 FirstFirst ... 2028293031324080 ... LastLast
Results 291 to 300 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #291
    Pacific Paradise QLD
    Quote Originally Posted by abstruse View Post
    I tried to update my 1T0035680C from SW 2760 to 4120 today and it seems to get stuck.
    It picks up the SWL-CD and begins the install then after a reboot or two it searches for a SWL image, and then says "not a valid swl source"
    Should I be able to update straight to 41xx from 27xx? or should I try an 3xxx or SW Downgrade first?
    Burn it on a different disc at the slowest speed possible Use a DVD-or + R with IMGburn and you should have no trouble I had to go to 39xx and then to 4020 and 4120.
  2. #292
    Nov 2009
    Quote Originally Posted by aussietig View Post
    Normally does sort itself out when you're outside!
    Did you load some custom POIs as well? They do take some time for the unit to digest on first install.
    Have you looked at how many satellites it's locking onto (when outside)?
    Might be a dodgey antenna or the location you have it (assuming it's a puck antenna).
    If GPS reception is fine, then which version unit have you got (under a proper VCDS scan)?
    Might just be an older and slow unit.
    Put a destination in and go for a drive mine didnt reorient until I did that but only took half a K to do it then
    Thanks guys, all fixed just needed a longer drive!
    FYI This is a 'b' unit built june 2009, now updated with latest fw and maps. Cheers fellas!
    Volvo S60 RD T6
  3. #293
    Sep 2006
    Hmm, did 3x firmware and don't have a hdd any more ? Any ideas?
  4. #294
    Re: Firmware updates for RNS510 units in Australia/NZ
    Quote Originally Posted by Darks RS View Post
    Do you mean music has been wiped and you need to load from sdcard again?
    Sent from my HTC One X using Tapatalk 2
  5. #295
    Sep 2006
    Yeah, the hdd got wiped, no biggy though as the additions outweigh my crappy music collection.
  6. #296
    Jan 2012
    Epping, NSW
    Remember all loads here are generally customised by the good people here to have the 90/5/5 partition size split, so if you aren't running customised already, it will wipe to achieve this new position size arrangement.
  7. #297
    Sep 2006
    Yes, understood and overall very happy with the update.
    speed limits on maps - tick
    F&R park assist whilst reversing - tick
    different F&R sensor screen - tick
    but, whem I do set up - version now, it no longer says its a B unit, but no says its a 'D' unit? wtf!
    Quote Originally Posted by tonymy01 View Post
    Mine:2012 MY12.5 Amarok |Natural Grey |RCD510|Premium Bluetooth
    Hers:2012 MY12.5 Passat TDI|White|RNS510|MDI|Premium Bluetooth|Park Assist 2 | Sports pack | Tints
  8. #298
    Nov 2009
    I might add that even tho mine is only a 'b' unit, with this latest fw and maps, route calculations and navigating around the screens is def quicker.
    Volvo S60 RD T6
  9. #299
    Its just the part number. The hardware is no different, refer to the hw version 0xC ..
    That does not change.
  10. #300
    Feb 2013
    VIC
    Successfully updated my unit (3T0035680A)
    Firmware 4120.
    Installed map and personal POI's.
    Whole process was smooth. thank you very much for great instructions
