Page 24 of 112 FirstFirst ... 1422232425263474 ... LastLast
Results 231 to 240 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #231
    Mindarie, Perth (WA)
    Quote Originally Posted by R36 DSG View Post
    Thanks guys, I guess I'll stick with 3810 as it's working perfectly with my A version.
    I have 4020 on my A unit...no advantage at all. Best to stick with 3810. Well done.
  2. #232
    Jun 2012
    Portugal
    Quote Originally Posted by FJ Steve View Post
    It depends what version/Model unit you have.
    I have always felt that installing new firmware in incremental steps is the safest option.
    Thank you (C HW50 SW2840). In secret menu in the option HDD status I see that it has a 40Gb HDD and 3 partition (is that possible with SW2840?)!!. So I think that I can directly update to 4020. What do you think?
  3. #233
    Oct 2012
    I upgraded to the 38xx firmware and I can't load maps (put cd in, nothing happens, maps show up in settings as Aus/NZ but when I view navigation it doesn't show any terrain nor can it calculate paths). After about 10 minutes the entire unit locks up. Any ideas?
  4. #234
    Oct 2012
    Quote Originally Posted by Bradaus View Post
    Didn't get a chance to test it thoroughly, but i rolled back to 2760 and nav seems to work again. Not sure if it still has the freezing problem. Will try again tonight.
  5. #235
    After you upgrade to 38xx you have to reload the maps.
    It can take a while (up to 30 mins or so) and during that time the nav will be fairly unresponsive as its loading from the map disk rather than hard drive, so its slower. Also unless you have a satelitte signal (ie if you are in a garage) it wont be able to give a position, so will display a blank map.
    Insert the map disk, wait a few mins and then press eject. It will warn you that its loading maps, and you can get a progress bar.
  6. #236
    Oct 2012
    Yep, i did that. even with satellites locked an my location found, the map wouldn't go to my location. regardless, the device froze up and became completely unresponsive after 10 minutes or so, so I'm guessing my device must be too old for 38xx firmware.
  7. #237
    Aug 2011
    Here's a handy tip for those with the secret menu enabled.
    You can find both your GPS speed and your true Speedo speed, which is handy for long highway crusing.
    To find your GPS Speed, go to the Secret Menu (Hold down setup for 20 seconds), then Navigation -> Matched Position, scroll down and you'll see the speed the GPS thinks you're doing. On my Polo this shows a 110 KM/hr when my MFD shows 117. I'd recommend having at least 4 sats/3D fix if you're relying on this to not get a ticket.
    To find your true Speedo speed, go to the Secret Menu, then Navigation -> Dead reckoning, scroll down to CAN Speed.
    This is what your car thinks it's going at. On my Polo this showed as 111KM/hr when my MFD shows 117. Non-standard tyres or wheels could mess this up though.
  8. #238
    Melbourne, VIC
    Hi there folks,
    Thanks for your help with all the firmware troubles. Have successfully upgraded from 2680 to 4120 today.
    Does anyone have a copy of V5 maps? I can't seem to find any working links.
    Happy to throw some beers in for your troubles. I'm based in Windsor in Melbourne. I also have a Micro-CAN Interface if anyone needed to borrow it.
    Thanks,
    Josh
    2010 Mk6 GTI / CW / 3dr / DSG / 18" Detroits / RNS-510 w/VIM! / RVC / Bi-Xenons / MDI / Euro Plates / 9W7 / VCDS Micro-Can / APR Stage 1
  9. #239
    Apr 2010
    Look in the 'look here first' sticky thread in the audio section of the forums.
  10. #240
    Melbourne, VIC
    Thanks Ryan. Found the link. Appreciate your help.
