Page 2 of 112 FirstFirst 12341252102 ... LastLast
Results 11 to 20 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
    Apr 2012
    Germany
    Did the HDD work prior to the firmware load?
    If it did, go into the hidden setup menu by holding down setup for 20 seconds.
    Then get the HDD information and post here, may get a better idea of what the issue may be.
    thank for the continu support,
    when i go to the secret menu there isnt any info about the HDD, just the HW info and map info,
    the HDD always worked fine had like 7 GB music on it,
    HW= H02
    SW= 3810
    Part = 1T0035680D
    note my device is originel B
    waiting for your reply
    Keep holding down the setup button until you get a new menu with many more options.
    Apr 2012
    Germany
    Thank you for support
    please find the info,
    i managed to add the music to the HDD now, the only problem is the POI are gone when i try to add them it says wait please
    probably because is still copying the MAP?
    Support Status : HDD supported
    Tempstatus : Degraded
    Power Status : ok
    TEmpstatus : --
    HDD read size 30005821440
    Number of partition = 3 Partition
    Volfile system = filesystem_f..
    Volumsite- 26977769928
    Remaine size = 26977751040
    Firmware version = F4rjas03
    Model = Hitachi HEJ425030
    Dec 2006
    Kilsyth, VIC
    I played the game today too and it really did take about an hour for the firmware upgrade:
    and finally... Done!
    I did have the system upgraded when I first got it and must have had a 90/5/5 split because it seems that my maps and POI's are still there (I have an iPod for music).
    What was a little strange was that when the system came back up I had a blank map screen (just the little red arrow) and nothing else. To be fair the system was showing 0 satellites so I backed it out but even with 2 satellites there was no map and trying to select a destination made the system say something along the lines of "no route for this destination".
    Putting the map CD in didn't seem to prompt the install of new maps but a quick drive seemed to capture more satellites and the system started working. Mind you I had a moment when I went to eject the maps as the system said it would cancel guidance (it looked like it was using the disc rather than the HDD). Ejecting the disk did stop guidance but I was able to re-select the route again and it seemed to work fine... and like I said my POI's are still there. The real test will have to be a decent drive somewhere, will just have to make sure I through the map CD in the car on the off chance something is not quite right.
    But yeah... done... So is there anything new/better in this release?
    Melbourne, Vic
    Mine also took about 30 mins for the system to find satellites after the upgrade. Seems fine now though.
    2010 Candy White Golf GTI 5Dr. Manual, RNS-510, Bluetooth, Tints, GT-CX 18 Gloss Black Rims.
    Aug 2011
    I've noticed if you apply the 90/5/5 firmware to a normal system it won't actually re-partition it. Looks like you need to format the hdd first or have a new hdd.
    You'll need to be more specific... What do you mean by 'normal'?
    Jan 2012
    Epping, NSW
    I did this update last week on a previously not updated (apart from maps) system, and it seems to have formatted the drive appropriately (as I lost my music and maps and pois).
    Aug 2011
    It was a H61 01.2012 with 40gb hdd, 3970 firmware and V4 Aus Maps. Firmware updated fine but I still had my maps afterwards. Checked HDD capacity and it was 18GB
    First I've heard of it. You could force a downgrade to 26xx and then upgrade again to 402x which would repartition to two and then again to three.
