Sounds like you've already sussed out the unzipping so the next step is burning the ISO file (which in itself is somewhat like a ZIP file as it contains a lot of other smaller files inside it).
The process all depends on what software you have but the easiest way to work it out is probably to check a YouTube HowTo video:
how to burn an iso - YouTube
No sweat, Murray. I hope it all works.![]()
MkVI GTD fitted with Bluetooth & MDI, CSG, DSG, Xenons, RNS510 with Dynaudio, ACC, Weathershields, Mudflaps, Sunroof, LED Tails, LED Indicators, LED Foglights, Interior LEDs, Tinted, RVC and Towbar - Gosford.
Thanks GTD,
All appeared to load ok and the system did not report any errors BUT since then
1. I have found it to be exceptionally slow to load up
2. Have reloaded maps but they don't want to appear although system indicates their presence
3. Unable to stream music via Bluetooth from iPhone
4. RNS constantly reboots without notice
5. Locks up on certain screens
6. No audio on DVD's (** Update - now no audio on anything**)
7. Have attempted to update maps to V5 with no luck
These are the issue I have found thus far and also notice that the FW upgrade has changed my system from a C version to a D version.
All help appreciated
regards
Murray
Just revert back to FW 3970, if you're having that many problems on your C unit.
There's absolutely no material gains under FW 4020.
MY11 Tiguan 147TSI (SOLD)
Thanks Aussie, I think I have the issue semi sorted in that my hardware version is actually a B unit (according to VCDS) and not a C as was showing on the hidden menu (setup button) and I have/had loaded 4020 when I should have loaded 3810. I have just loaded 3810 onto my RNS and all appearsto be working except audio on everything so I'm guessing this may be a coding issue and I will check this tomorrow at work when I can get my lappie into the car.
I'm about to try V5 maps to see if I can correct that small issue as well.
cheers and thanks again
Murray
**** UPDATE ****
Audio issue was a coding issue and I have now corrected that via VCDS. Maps V5 works a treat (still lags behind where car actually is though). POI works a treat. Haven't tried VIM as yet and Blueetooth streaming audio is still not happening for me but I will persist. If anyone has any suggestions (keep them topic centered please) I would be appy to give them a try.
cheers
**** Further Update ****
Bluetooth audio streaming now fixed (coding issue). VIM works a treat but don't recommend it as can be very distracting. Changed intro screen and had initial problem with the error that seems to come about if you don't burn on a quality disc at the slowest speed possible. I ended up using a TDK CD-R burnt using XPCDBurning at 1x (track at once) with outstanding results. Also used Netdata to build my own intro screen but have not loaded it at present.
cheers
Updated to FW 4020 with custom POIs . . . now have speed cameras etc.
Great instructions, worked like a charm, had no problems. Thanks guys!
MY12.5 B7 Passat Wagon : : TDI Highline : : Icelandic Grey : : black leather interior
sports pack | sat-nav | panoramic glass roof | adaptive cruise control | driver/lane assist | bi-xenons/LEDs | RVC plus | auto-park | auto tailgate | tow-bar | mud-flaps | sill-protection | wood trim - ||| - Lakin plate mounts | tinted | Opti-Coat | LED reverse lights | bright white driving lights + turn lights (LEDs were too 'dim')
Does the 40xx firmware in the 1st post include the POI's in this thread?
Custom POIs with 3xxx firmware, Aus/NZ Maps v 4.1 and POInspect0r
2008 Skoda Octavia Elegance TDI 4x4 wagon
Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
POI's can only be included with Maps discs, not firmware. Then there's a secondary set of separate Personal POIs.
Here's the v4020 firmware:
https://docs.google.com/uc?id=0B4fMk...xport=download
Here's a v5 Map CD with POIs included:
https://docs.google.com/uc?id=0B4fMk...download&pli=1
I'm planning on doing the upgrade to FW3810 tonight.
Currently have a 1T0 035 680 B with FW1120.
Doe I need to intermediate upgrades? or do I just go for it?
