Page 13 of 112 FirstFirst ... 311121314152363 ... LastLast
Results 121 to 130 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #121
    Mindarie, Perth (WA)
    Can't recall mate. But I think it may have been able to calculate it. I know the Garmin bling bling in my wife's Polo can do it.
  2. #122
    Jul 2010
    Perfectly normal ... whenever I put in a WA address, my unit returns "Catch a plane you tight@$$!".
    MY11 Tiguan 147TSI (SOLD)
  3. #123
    Apr 2010
  4. #124
    Here you go
    Firmware 4020 with modified partitions (for Australian/NZ Version A units)
    FW_4020_A.ISO - download now for free. File sharing. Software file sharing. Free file hosting. File upload. FileFactory.com
  5. #125
    Thanks Steve
  6. #126
    Nov 2009
    Quote Originally Posted by FJ Steve View Post
    Here you go
    Awesome Steve thanks for that!
    Do I need to activate downgrade in the secret menu to load this firmware given that I am already on 4020?
    Sorry I meant to reply to your post thezoneR32's...
    The last portion of the firmware load, VUCI which is reporting the failure may indicate that the tables it is trying to copy are not compatible.
    You mentioned that you have a B revision unit I think so the 402x image that you are using needs some of those tables swapped around in order for you to use it. We have not made this widely available due to possible issues however FJSteve is running it on his A unit without issue as far as I am aware.
    You have two options here: downgrade to the 381x image from the beginning of this thread which has the tables swapped for compatibility with your unit, or ask FJSteve to make the 402x image with table swaps available for others to try.
    kamold, I already downgraded to the 381x image from the beginning of this thread which also gave me the swl error screen that I posted. I will try this new 4020 and see how I go.
    Cheers guys great thread!
    Volvo S60 RD T6
  7. #127
    Yep need to do a downgrade.
    If this doesn't fix your issue then there may be an issue with the unit.
  8. #128
    Canberra
    Just a note: I upgraded a '11 and '12 build Rocco with the files here, burnt to CD (Benq) at the slowest possible speed, without problems.
    The RNS in both detected the CD without the need to press the buttons to restart the unit. Both took 57mins for the firmware, plus the Nav disc.
  9. #129
    Apr 2012
    Gosford, NSW
    I have read through the whole thread and I have a question from a real novice on this sort of thing -
    In the first post it says for upgrading to -
    Firmware 40xx -Links (thanks to JohnC) Part 1 Part 2 Part 3 Part 4 Part 5
    1. Do I have to download all 5 parts and combine it into 1 cd? Or,
    2. Can I just use the link provided
    and burn one cd from this link please?
    Apologies if this has been answered before or I just don't have the knowhow to work out what I should do.
    MkVI GTD fitted with Bluetooth & MDI, CSG, DSG, Xenons, RNS510 with Dynaudio, ACC, Weathershields, Mudflaps, Sunroof, LED Tails, LED Indicators, LED Foglights, Interior LEDs, Tinted, RVC and Towbar - Gosford.
  10. #130
    Jul 2010
    You need to work out which version unit you have first.
    A, B, C, D or higher?
    The five part link (and yes download them all and combine with say winrar program) can be used for anything other than A unit.
    Second link is just for an A unit.
