Page 12 of 112 FirstFirst ... 210111213142262 ... LastLast
Results 111 to 120 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #111
    Quote Originally Posted by Jase View Post
    This 4020 firmware upgrade, is it seemless on the Skoda Columbus'? I think 1 or 2 upgrades ago two files needed swapping so that either the bluetooth phone or steering controls work properly & just want to make sure that doesn't need to happen again.
    That only applies for older cars. Your profile mentions a MY12 Superb so you can just go right ahead with the upgrade.
  2. #112
    Apr 2011
    Springwood NSW
    Worked well for my MY11 Superb Columbus. Hardest part was finding the right media to burn on. Ended up going with TDK-RW DVD, burning Track At Once at slow speed (4x). Loaded the new Skoda startup screen too.
    By the way Kamold and JohnC, thank you for your great instructions! Just thinking that you may want to add how to join multiple RAR files to make an ISO though. Not something that most people would do very often.
    MY11 Superb Elegance Estate Amethyst Purple 3.6 V6 FSI 191kW DSG 4X4, Glamour Onyx Leather, Panoramic Roof, Sports Suspension, Multi Function Wheel, Sunset Glass, False Floor, Power Tailgate, KESSY, MDI, Bluetooth.
  3. #113
    Dec 2008
    MANSFIELD VIC
    Kamold & Parkesy, thanks for the info. Looks like I am very safe to proceed. Yes, will make sure I get some decent media. Seems like TDK gets the rave thumbs up across many forums that I have read.
    HAVE: '12 SUPERB ELEGANCE SEDAN 103kW 4x4 TDI DSG | LAVA BLUE | SUNROOF | KESSY | 3x BLINDS | PARK ASSIST | PADDLES | TINTS | NOKYA YELLOW FOGS | TOWPACK
    HAD: '09 MKV JETTA TDI DSG | SALSA RED | XENONS | TOWPACK
  4. #114
    Sorry I meant to reply to your post thezoneR32's...
    The last portion of the firmware load, VUCI which is reporting the failure may indicate that the tables it is trying to copy are not compatible.
    You mentioned that you have a B revision unit I think so the 402x image that you are using needs some of those tables swapped around in order for you to use it. We have not made this widely available due to possible issues however FJSteve is running it on his A unit without issue as far as I am aware.
    You have two options here: downgrade to the 381x image from the beginning of this thread which has the tables swapped for compatibility with your unit, or ask FJSteve to make the 402x image with table swaps available for others to try.
  5. #115
    Mindarie, Perth (WA)
    Uploading the 4020_A now
    Confirm that this is the one, Kamold?
    #CD 0 0 5 . 4 0 1 . 3 0 2
    #DATE:2011-11-17
    #Project: VWRNS
    #Author: RoNe
    #Steckbrief: C_EU_10.354_t1 C6/C10/C12
    #CommentStart:
    This is a SWL CD for VW delivery.
    #CommentEnd:
    #Integrationphase: Delivery cw22/11 C6/C10/C12-samples
    #VwSwPartNumber:1T0035680D/3T0035680B/7F0035680A/7E0035680A/1T0035680F/1T0035680G/3T0035680C/3T0035680D
    #VwSwIndex:4020/4026/4028/4024
    #AppsBuild:C_EU_10.354_t1 C6/C10/C12
    #CRC16:d6d9
  6. #116
    Yeah it's the one you made where you had to replace the dlscript.txt file to partition the hdd correctly.
    All still working well for you?
  7. #117
    yep...
    1 small issue. If someone on the east coast could plug in a general POI (service station or GPO) for Perth Wa...see if the RNS calculates the distance/time. Not doing it for me for East Coast POI's
  8. #118
    Quote Originally Posted by FJ Steve View Post
    yep...
    C'mon Steve put in the effort! Test the time to get to the Caltex in Lakemba from your place...see how accurate it is
  9. #119
    you're closer to the real reason for me asking the question, than you think.
    Everytime I put a Vic, NSW or QLD POI/Address into the RNS...it tells me it can't calculate the route. Adelaide/SA is fine....but the rest is zilch. It will show all the POI's for Qld/NSW/Vic, but won't calculate the route etc
  10. #120
    Oh really? That sounds a little odd. I mean you leave the Perth GPO, head south, then south east and then go to sleep for about 8 hours until you hit Ceduna...how hard can it be to calculate?
    Do you know if it used to do that in the past or was behaviour different?
