Shared Links to both disc iso files
RNS510 OEM AUS firmware update 6276
RNS_510_OEM_AU_FIRMWARE_VER_6276.iso - Google Drive
Hawkedit: Removed copyrighted maps. If you can provide a link to an official source I'm more than happy for it to be shared.
You have the rechesburg????? syndrome and if you look back quite a way in the threads you will see it was quite common for a while and the solution to fixing it is there also Need to go back about 7 years or so Page 87 first post tit and go for a drive for 30 mins to let it find where it is ONLY PUT 6276 if you have A LATE MODEL DAB model 5238 is enough
cant be the drive,
i drove it to sydney and back (im in wollongong) thats about 2 hours there and back... its in german, wont change back...
also, i have lost all sound in the unit..
im happy to do a firmware update, would rater reload what i already have though to keep it the same,i tried to load the verion on page 1 but it tells me in trying to downgrade and it wont allow it.
fyi, delivery part number 1t0035680L
hw version h09
sw version 5238
map version 7920
the error code i get is 010304
it says target is loaded with 5670902 and inserted media is the same..
wont let me re-load it.
any way to force a reload? to try and get the english language pack and stereo sound to work?
realy appreciate your help so far.
is there a way to reload the firmware that it already has?
You can reload the same version. It's considered a 'downgrade' as it's not going to a higher version.
Enable developer mode and then go into the menu and enable software downgrade.
well, I stand corrected. Cheers J (@kamold )
