Page 107 of 112 FirstFirst ... 75797105106107108109 ... LastLast
Results 1,061 to 1,070 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #1061
    Pacific Paradise QLD
    Quote Originally Posted by sheekat View Post
    Hi everyone,
    I have a 2013 VW Passat. One day, the language on the RNS 510 turned to German and the sound is gone. The system looks fine, but there is no sound from the speakers. When I try to change the language back to English, the system gets stuck. I also tried the basic things like reset and battery release but didnt work. Please help.
    GOOGLE Regensburg syndrome or/and read this
    RNS 510 points to Germany on cold start everytime
    A bit naughty to multipost same thing across different forums
  2. #1062
    Nov 2021
    Druskininkai, Lithuania
    Hey guys,
    Does anyone have a 6270 or 6276 FW with hdd format and re-partitioning?
    I have a unit with new SSD, which had 6270 FW originally, but the problem is that software downgrade is not turned on, so I cannot install any older FW than 6270. And any 6270 or 6276 version that I can find is failing on HDD 6% error writing file.
    As I went to Software update menu and my updates failed, so I cannot get my unit to work now. Driving in silence is nuts.
    Can anyone help, please?
  3. #1063
    Jun 2013
    Holsworthy NSW
    Hi everyone,
    I think I have the exactly same thing happened to my 2012 Tiguan , the firmware was corrupted and you'll need to reload the firmware and map. I had my RNS510 back to working order after reloading the firmware and map.
  4. #1064
    Quote Originally Posted by someon3 View Post
    Read reply 1064
  5. #1065
    Oct 2022
    Hi everyone,
    I have a 2013 VW Passat. One day, the language on the RNS 510 turned to German and the sound is gone. The system looks fine, but there is no sound from the speakers. When I try to change the language back to English, the system gets stuck. I also tried the basic things like reset and battery release but didn't work. Please help.
    Three days ago my 2012 Skoda Octavia 118Tsi did the same thing! It was working perfectly one day and then the next day on starting the car the display went black and showed the message 'SWL error, Initialising.....please wait' then nothing happened for a long time. Finally it switched to German, cleared the radio of all preset stations , lost all sound and then got stuck when I tried to set it back to English.
    From reading this forum it seems the solution is reloading the firmware and map. I am clueless and don't have any of the equipment such as a burner etc so I've booked the car in at my local Skoda dealer to do it. (Skoda Artarmon in Sydney).
    My questions are
    1. Any idea as to how much is this likely to cost?
    2. What firmware etc should I have installed for the most reliable performance going forward? Should I get the same firmware version reloaded again or is there a better more stable version available now that would prevent this happening again?
    3. If the maps also have to be reloaded, I might as well get the latest version compatible with my unit, what would be the most up to date version that will work with my unit once it has been repaired? Currently I have 7679.
    The hidden menu on my car currently shows the following:
    Delivery part number 3T0035680B
    HW-Version H55
    SW-Version 3984
    Active map coverage Australia + New Zealand
    Active map supplier Sensis
    Map version HDD 7679
    Thanks to all in advance.
  6. #1066
    Quote Originally Posted by Villageidiot View Post
    My questions are
    HW-Version H55
    SW-Version 3984
    Latest map is V10 and only place Ive seen it for sale is Euro Car Performance upgrades - ECU remaps - Navigation - Bluetooth - Latest Australia GPS maps - Auto electrics and is $175
  7. #1067
    Oct 2022
    Thank you, I'll ask my Skoda Service Centre if they have it too. Any ideas as to which firmware I should get to avoid /minimize the chances of any future reliability issues?
  8. #1068
    Kamold will know I havent had one for several years. Read the first post in this thread The latest info is there so have a look
  9. #1069
    I wouldn't have a dealer do it unless you are allergic to the money in your wallet.
    You should find a friend to burn 5238 firmware for you and load that.
    Buy v10 maps as well and you'll still be in a much better spot than what a dealer will charge as they will more than likely charge for diagnosis and then tell you you need to spend $3k on a new unit.
    Sent from my SM-G781B using Tapatalk
  10. #1070
    Mindarie, Perth (WA)
    In my experience, dealers have no access to Firmware etc
    I once had a Service Manager call me and ask if I could talk to a 'good' customer of his who needed a firmware fix on an RNS510. SM said VW couldn't assist him, but he knew that the software I had could sort the customer it. All under the table of course
