Page 102 of 112 FirstFirst ... 25292100101102103104 ... LastLast
Results 1,011 to 1,020 of 1115
Thread: Firmware updates for RNS510 units in Australia/NZ
  1. #1011
    Mindarie, Perth (WA)
    FW5328 provides much less "errors" for the unit, therefore is a much more stable platform. It may/may not enhance interface speed, but having had it on my RNS510's for quite a number of years now, there have been zero screen freezes, zero issues and the unit has worked flawlessly. Also, the number of 'recorded errors' (displayed via the hidden menu) have been considerably less than previous versions (4120 included).
    Hillbilly is right about the new generation units. RCD330+ etc. The RNS510 was a good solid unit but there are no more updates for firmware or maps. Spending money on a new generation RCD is a wise move.
    Lots of info in this thread.... Replacing RNS 510 with RCD 330+
  2. #1012
    Jun 2020
    Kensington, NSW
    Hi KAMOLD,
    Thanks for providing this detail, you’ve helped a lot of people.
    i just want to double check as this is a favour for my bosses family car and a wrong move will either solidify our friendship or end it, no pressure.
    They have the 2012 Skoda Octavia, Melbourne based and its defaulted to German mode. The unit has the following specs
    3T0035680B
    HW Version H60
    SW Version 3984
    Map Aust/NZ - 7492
    Map Supplier - Sensis
    Just checking that loading the Firmware 523x link on the first page of this thread is the right approach?
    Many thanks,
    Mickeo
  3. #1013
    Quote Originally Posted by Mickeo View Post
    Hi KAMOLD,
    3T0035680B
    HW Version H60
    SW Version 3984
    Map Aust/NZ - 7492
    Many thanks,
    Mickeo
    Yes 5238.
    Sent from my SM-G960F using Tapatalk
  4. #1014
    Jun 2020
    Kensington, NSW
    Yes 5238.
    Thank you
    just confirming 523x, not 5238, sorry mate, I just want to stuff this up
  5. #1015
    Yes 523x.
  6. #1016
    Jun 2020
    Kensington, NSW
    Yes 523x.
    Thank you, have a great weekend 🙂
  7. #1017
    Jun 2020
    Hi Guys
    The short version:
    I'm in Sydney: is there anyone out there with a 5238 disk that works in their RNS510?
    My CD writer may be suspect and I'm trying to revive my RNS510.
    The long version:
    I have just bought a 2010 Tiguan and the RNS510 stopped working after a few weeks.
    The unit will switch on but displays nothing but a plain white screen (no logo). Radio, phone etc. does not work.
    I removed the unit and it is a 1 T0 035 680 C (HW:H41, SW:2720 and S-date: 04.07.2010)
    I have burned 6 CD-R and DVD-R disks (using recommended programs) with the 5238 ISO file but the RNS510 doesn't complete the firmware update process and spits the disk out without displaying the standard progress screens.
    I have tried the AU_FW_5238_90_5_5.iso file and a 2720 file from my-gti.com.
    If there is no firmware disk in RNS510, it cycles through startup attempts and displays a blank white screen for 3-4 seconds and then goes dark except for an intermittent flicker of light at the top of the screen.
    When there is a firmware disk in the unit, it will eject it after about a minute's intermittent activity (CD Read sounds and HDD sounds).
    It will then display what appears to be a very big, out of focus letter "O" (the edges of the screen is dark and the middle is a white ellipse).
    Questions:
    1. I think my little plug-in CD/DVD Writer may be suspect. I would like to try a disk that is a known quantity to eliminate the potential CD/DVD disk quality as variable. Is there anyone in Sydney with such a disk for me to try?
    2. Is there anything else I could try?
    Appreciate any help!
    Cheers,
    AW75
  8. #1018
    Jul 2020
    Sarajeco
    HI,
    I buy Octavia 2012 and in Columbus,3T0 035 680B hw H64 sw 4024 and map W Europe 7690, I need East Europe Croatia,Serbia,Bosnia and Hercegovina .What can I do.Thanks.
  9. #1019
    Jul 2020
    Sarajeco
    Can I put map v15 without software update
  10. #1020
    Pacific Paradise QLD
    Quote Originally Posted by Sijalica View Post
    Should be able to. Try it and see
