The maps partition is not a format that you can access from a computer.
You need to use the DVD drive. If the DVD drive is broken you'll need to replace it.
Or what about removing the hard drive from the rns510, putting it into the computer and copying across?
As you have to completely disassemble the 510 to get the HDD out it might be a mission.
If you want to try this thread shows how Have fun
RNS-510 HDD replacement/SSD swap DIY
Would be easier and possibly cheaper to buy a new DVD drive especially if you damage something
I simply wanted to avoid having to buy a box of DL discs when I only need one, £20 is cheapest I've seen. I'd load v8 maps without poi's if I could find a reliable link.
Wrong thread, I should have looked in the Australian one![]()
It will likely come with 5238.
Sent from my HTC One using Tapatalk 2
