Page 20 of 41 FirstFirst ... 10181920212230 ... LastLast
Results 191 to 200 of 404
Thread: Firmware updates for European RNS510 units
  1. #191
    Apr 2013
    france
    Hasnt been any comment on here about that Didnt affect my camera
    you diden't re-enabled the cam via vagcom ?
  2. #192
    Pacific Paradise QLD
    Quote Originally Posted by debiansid View Post
    Put the disc in upgraded to 4120 put the V6 maps in and drove it away I dont have a cable or software and it all works.
    Mine came all factory with RNS510 and RVC camera and with Park assist 2 All the enchiladas LOL
  3. #193
    Re: Firmware updates for European RNS510 units
    This firmware update will not erase the coding. All existing features will remain enabled.
    Sent from my HTC One using Tapatalk 2
  4. #194
    Apr 2013
    france
    Hello,
    upgraded to 4120 successfull ! I'm transferring the maps ! Do you have the change log ? I move from 2720 to 4120 firmare. What the most important news features ?
  5. #195
    Apr 2013
    france
    4am here read through the thread and u will see
    Sorry ?
  6. #196
    Refer to this list for main features.
    4120 adds RDS support and male navigation voice (at least for English language, not sure about other languages).
  7. #197
    Apr 2012
    Germany
    i am EU User on C device, and want to use 412x FW,
    what are the features? do i still need the map disk?
  8. #198
    See the post immediately above yours....
    If you are repartitioning the hard drive you need the map disk. So if the current firmware is 2xxx series then the hdd partitions will change.
    And if you are loading a custom firmware with modified partition ratios the hdd will be wiped also.
    So you need to have the map disk on hand for the upgrade.
  9. #199
    After installing the firmware, is it possible to load the new maps via sd card?
  10. #200
    Mindarie, Perth (WA)
    Quote Originally Posted by rhinopower View Post
    wouldn't think so. CD/DVD only
