Page 14 of 41 FirstFirst ... 4121314151624 ... LastLast
Results 131 to 140 of 404
Thread: Firmware updates for European RNS510 units
  1. #131
    Quote Originally Posted by R1 Crasher View Post
    Hi I have done a download of FW_4020_70_20_5.ISO (689.64 MB)
    But for some reason its only downloaded 657 MB will this work?
    No.
    Sent from my HTC One X using Tapatalk
  2. #132
    May 2012
    France
    Hello from France,
    If I am not mistaken, it seems to me that it has errors in files modified in firmwares FW_4020_70_20_5.iso and SWL_CD_4020_M3_EUR.iso
    in EURPQTO.WSH It is written
    # Testmode: ActiveSetRegDataHex(0x21,"01",0x0,0x1,0x1) # Speed limit DVD/TV: 300km/hSetRegDataHex(0x0B3A,"012C",0x0,0x2,0x89)
    He It should be written :
    # Testmode: Active
    Same in EURSKHDD.WSH
    The code of the character "return to the line" is not good.
    Excuse me for my bad English and I am not a specialist, but some meet problems with these firmwares
  3. #133
    The delimiter of 'return' or next line is not required. It only makes it easier to read for humans.
    Some people have loaded the firmware without issue. Those that fail are likely due to media read errors.
    Feel free to edit the file as you like, this file is not protected by a CRC.
  4. #134
    May 2012
    France
    Hello,
    I do not agree.
    The code 0A is not enough to indicate the beginning of the line of command. Like the "bad file" program undestand all as line of comment.
    If "test mode" is a compulsory data to be configured, the program stop and fail.
    Can be it is the same matter for the formatting 75-20-5
  5. #135
    Test mode is optional.
    As you have pointed out in your image, there is a . in between the comment 'test mode: active' and the actual setting 'setregdatahex'. You can have one . or you can have 99 .s and the setting will still be applied.
    The formatting is controlled by a script file that is CRC protected however so it cannot just be edited without affecting the resultant CRC.
  6. #136
    May 2012
    France
    OK I am not a specialist BUT
    all beginning of command line in original firmware start with 0D 0A code exept with you modifed command line.
    It seems to me important to try to understand why the version for RNS B C D.. do not work while that for RNS A and previous seem good to work.
  7. #137
    As I said you can edit this file so you can test your theory. Other people have been able to load it to c or later units.
    Please do let us know if after you edit the file it makes a difference.
    I don't think it will but would be happy to be proved wrong.
    Sent using electrickery
  8. #138
    May 2012
    France
    If you not be convinced, I am not going to flash my RNS (HW52 / FW2840 - 1T0 035 680 C) because I went to preserve it in working order.
    As I said, I am not specialist, just curious.
  9. #139
    I am convinced but if you aren't then as I mentioned you can edit the file.
    I have been wrong in the past.
    I think it was in 1992.
    Sorry I'm being a bit facetious...
    If you don't feel comfortable testing it then use the stock 4020 fw image.
  10. #140
    May 2012
    France
    I have a hard time expressing myself clearly in English. I do not mean to say you're wrong, i just want to understand why there are so many negative post about the 4020 update (new RNS) for Europe.
    I do not think this is due to burning because too many different people have problems, always at the same time of the update.
    Modify partitions is a real advantage of your firmware. Can we change the formatting in 70/25/5 instead of 75/20/5 without modifying CRC ?
