Page 11 of 41 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 404
Thread: Firmware updates for European RNS510 units
  1. #101
    Apr 2012
    Germany
    Quote Originally Posted by kundatra View Post
    You can burn the CD on lower speed. X8 speed on it is maximum write speed of the media.
    if your post mean for me,
    i tried to burn the DVD at lower speed X1 no avail!
    always disk Error
  2. #102
    Mindarie, Perth (WA)
    Quote Originally Posted by jamerson View Post
    always disk Error
    What burning software are you using?
    What DVD media (brand) are you using?
  3. #103
    Apr 2012
    Stockholm
    Thumbs up
    Performed update on my RNS 510 Rev. A
    Went from 3810a_noru to 4020 Modified
    Used Verbatim DVD-R, burned with cdburnerxp, 4x speed and Track at once.
    Enabled Downgrade in secret menu.
    Made an hard reset and the I applied custom bootlogo.
    Used TDK CD-R, burned with cdburnerxp, 1x speed and Track at once.
    New bootlogo, VIM and HDD partitions as promised.
    Loaded Western Europe v8 maps Speedcams Edition (cd 7692) to the HDD
    Everything works! No problems at all!
    Thanks alot!
  4. #104
    Apr 2012
    Germany
    Quote Originally Posted by FJ Steve View Post
    i tried Nero, Imgburn, cdburnerxp
    i am using like 5 different medias
    Platinum DL DVD,Imation, Philips,...
  5. #105
    Might be worth just trying a cd lens cleaner and see if that helps
  6. #106
    Nov 2009
    Can someone please tell me what the difference between these 2 x 4020 versions?
    This one is named 4020_a_B
    i am uploading the 4020 for Unite A/B/C for Europe users
    will share the links soon and please update the first link!
    http://api.viglink.com/api/click?for...13362681489593
    edite
    please add to the first post this 4020 for Unite A and B and C with European Partition
    & This one from the first page is named FW_4020_a_70_25_5
    Firmware 402x modified - Link (some tables have been swapped to allow compatibility with older units. Thanks to Josi)
    1T0 035 680
    1T0 035 680A
    3T0 035 680
    1T0 035 680 B
    I have a EU unit bought on eBay and wondering which is best for my unit.
    Volvo S60 RD T6
  7. #107
    The "Euro" firmware versions have the HDD partitions set at 75/20/5 (Music/Map/POI)%
    The Australian Firmware versions have 90/5/5% because our maps are significantly smaller in size (HDD space).
    What version EU unit did you buy from eBay? The 4xxx links here are for A/B/C, and a second edition for the later version units (E/F etc). The older uniuts (A/B) are a little temperamental with the 4xxx series, so some tweaks were done to enable them to load.
    FWIW...there really is no visible difference between 38xx aznd 4xxx...just e-penii bragging factor.
    Hit me with any questions or requirements, and I'll point you in the right direction.
  8. #108
    Just a note: the firmware in this this thread is for systems Physically located in Europe. Not those bought from Europe and installed in a car in Adelaide...
    Use the thread for aus firmware if you are in Adelaide (or anywhere else in Australia).
  9. #109
    Nov 2009
    I have moved my questions to the Aus/NZ thread as this is the more relevant thread! Sorry!
    Last edited by thezoneR32; 06-05-2012 at 04:56 PM. Reason: Questions posted in wrong thread!
  10. #110
    Jan 2010
    Portugal
    Quote Originally Posted by mylifeuncut View Post
    Thanks alot!
    You´re the only one to have done it right now.
    Strange.
    (every EU user has been having problems when installing the maps)
