Page 10 of 41 FirstFirst ... 8910111220 ... LastLast
Results 91 to 100 of 404
Thread: Firmware updates for European RNS510 units
  1. #91
    Jul 2010
    hey kamold - u reckon i'll b fine upgrading to the 4020 firmware on my rns510 (columbus)?
    like u, i have a my11 RS.
    currently running firmware 2724 on a 3T0 035 680 A (HW: H41; B: 26.08.2010)
    maps v5.1.
    i'm presuming i'll loose both the maps & music on the hdd?
    what about phone (bluetooth) - will it forget all the saved speed dials? user profiles?
    i've got a 9wz bluetooth unit.
    cheers...JR
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  2. #92
    Yep you can upgrade to 402x no problem. You will lose music and maps.
    Radio presets unaffected, bluetooth is a separate module so also not affected.
  3. #93
    Jul 2010
    took the plunge & did the firmware upgrade today.
    all good sofar - new firmware (4024) - reload maps (v5) - loaded POI provided.
    however i can't get the new logo screen change thingy to work, despite enabling software downgrade in the secret setup menu.
    i get a software error. oh well.
    maybe i need to burn it differently.
  4. #94
    Apr 2012
    Germany
    Quote Originally Posted by dArK5HaD0w View Post
    if you mean the boot log on,
    try to burn it as low as possible
  5. #95
    Yep usual situation. Use cdburnerxp at slowest speed using track at once recording. Only way I could get a custom logo to be applied.
  6. #96
    Jul 2010
    i've installed cdburnerxp.
    do u remember which burn method to use?
    - track at once
    - disc at once p-w
    - disc at once p+q
    - session at once
    the slowest i can record is at 1x.
  7. #97
    As I said use track at once...
  8. #98
    Jul 2010
    my bad - i didn't read ur earlier sentence properly.
    all good now.
    my columbus is now sporting a new startup boot logo.
    thanks again for ur help.
    now the long process of copying all the music back via sd card.........
  9. #99
    Apr 2012
    Germany
    do we have to use the same for the maps?
    can't get the Map 6792 EU to work always disk error on the navi
    and 1X speed? i've got DVD said x8 speed on it!
    means the lowest is 8 or i can go lower?
  10. #100
    Apr 2012
    Czech Republic
    You can burn the CD on lower speed. X8 speed on it is maximum write speed of the media.
