Let me check the modified script again when I get a chance. There may be a problem with the crc.
Sizes are 75/20/5 it was just a typo in the name.
CRC is correct.
I don't have time to look into further at the moment unfortunately.
What firmware revision are you at before loading the 402x (second link) firmware?
One thing to try would be to go back to firmware 276x and then load the 402x (second link from the first post) custom firmware. I have found that units already at 402x firmware are EXTREMELY picky about cd media. My unit never had issues before being at 402x but now it rejects most media to do custom loads of a boot logo.
I got it to work with cdburnerxp, track at once recording onto TDK gold media.
From the part number 1T0035680F, I presume it is a F unit.
I tried the file Capy posted earlier in the thread, SWL_CD_4020_M3_EUR.iso, and it got as far as the Gateway update where it would fail. But after using the swl_fix.iso to get the unit working again, it showed 4020 was installed and everything worked except voice commands.
sergiommms mentioned the 4020_nfb.iso a couple of posts ago, and I loaded this up and it worked a treat. It all works again including the voice commands.
The unit did have 3970 firmware from the factory.
One thing I did notice after I had used 4020_nfb.iso to successfully update the firmware to 4020 was that I had 3gb or so extra HDD space. I think this extra space appeared after one of my failed updates with the FW_4020_70_20_5.iso
Hello.I find out why i'm getting always "software loading error 010306".It seems that my Rns is a :" VW "Bluemotion" unit", with a different coding(3C0 035 680 C) and is not supported by this firmware.
From vag com :
Address 37: Navigation
Part No SW: 1T0 035 680 D HW: 3C0 035 680 C
Component: RNS-MID H01 3970
What to do now?
It's not a unit which is supported by this firmware.
