Page 6 of 41 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 404
Thread: Firmware updates for European RNS510 units
  1. #51
    May 2011
    Greece
    Sounds like I will have to have the ISOs created as maybe they were not built correctly. I thought that the previous instructions were clear but maybe they weren't...
    European maps are too large, you cannot use 90/5/5 ratios as there will not be enough room for the map data.
    Please Kamold make a new iso with correct 75/20/5 partition and VIM for European users. Thank you
  2. #52
    Apr 2012
    Czech Republic
    Yes Kamold, please ....
    I think, there is a little misunderstanding on the first page of this thread.
    Post Nr. 10:
    Europe 3810 you can download ready ISO
    https://rapidshare.com/files/1195943676/ISO9660.rar
    4XXX is coming soon
    Post Nr. 1
    Firmware 40xx - Link (thanks to jamerson)
    So both links are identical, what is correct now?
  3. #53
    OK first post updated with a new link for 402x firmware for older units. Has 75/20/5 partition ratios.
    Will make and upload the other ISO soon.
  4. #54
    May 2011
    Greece
    Wink
    Simply the best
    Thank you!!!
  5. #55
    Upload failed, have to try again...missing megaupload...
  6. #56
    Apr 2012
    Czech Republic
    Thank you Kamold!!!
    The first modified firmware you posted a short while ago is intended for the A unit version, but can be used in B and new unit versions, am I right?
  7. #57
    Yes it can, however I am uploading also the standard 402x firmware for C unit and later units that has VIM, secret menu and 70/20/5 partition ratios.
    It will take a while so won't be available until tomorrow my time. I will update the link in first post once it is uploaded.
  8. #58
    Apr 2012
    Madrid, Spain
    Hi,
    I've uploaded the ISO with the European version here:
    https://docs.google.com/file/d/0ByTp...BXajB6OEE/edit
    It works fine. It's the version I've installed.
    Regards!
  9. #59
    Apr 2012
    Germany
    Quote Originally Posted by andreas73 View Post
    I installed fw 4020 original and the 4020 with 90/5/5 partitions with success in my RNS B but couldn't install the maps because there is no space in HDD. Then I tryed the 75/20/5 one but the iso could not load (DVD-error). I have use different media, burners, MacOS X, Windows 7, downgrade option, reset memory, downgrade to 2760 but no luck. Then I tryed the new one jamerson upload but there is no new partition map in there. Can someone upload a good 75/20/5 iso (like the 90/5/5 with VIM enabled) please. Thank you
    Hey Andreas,
    if you are EU user and your Device B or C use this FW if not please provide more information and we will help you
    i already pm Kemold it wrong file on the first post he will edite it soon
    Quote Originally Posted by Capy View Post
    Hi,
    Regards!
    are you able to get your EU POI Working with this FW?
  10. #60
    The links are correct, not sure what you are referring to Jamerson? I just checked the link again.
    Links now available for all units.
