The ratio is 75% for music, 20% for maps and 5% for POI database.
Size of each depends on hdd size.
Nice one.
If you can post the links I will update the guide to just include the ISOs rather than instructions for how to create them.
You should not need to downgrade first, you just need to enable downgrade in the hidden menu.
There may be a problem with the ISO that you have created.
I will try and find some time later to make and upload the ISO..
One thing I have noticed at 402x firmware is the unit seems even MORE picky about CDs.
I never had any issues with mine in the past but after upgrade to 402x I had to use xpcdburner and track at once recording to get a custom boot screen CD to be accepted.
Maybe its worth doing a downgrade to 276x first and then upgrade to 402x....
Is it the burner or the media or the application used to burn??
I burnt mine using disk utility on a Mac on max speed (24x in this case) and Verbatim media and it worked fine first time.
On a side note, For people using windows I highly recommend imgburn, it's free, simple and awesome!
