Page 39 of 41 FirstFirst ... 293738394041 LastLast
Results 381 to 390 of 404
Thread: Firmware updates for European RNS510 units
  1. #381
    Jan 2018
    Azerbaijan, Baku
    I have an issue with deleting the folders from HDD, which is really annoying. Yesterday I upgraded FW to 5274 from 5270, but it did not format the drive. I tried to downgrade the FW yesterday to 5218, but it was not installed properly and gave an error. Installed back 5274. Now when I am attempting to delete any folder from HDD drive, the message with "deleting files" is stalling for a while and nothing happens.
    Looking for any solution.
  2. #382
    Quote Originally Posted by teymur88 View Post
    You can't delete the last file it's a silly limitation.
    If you add another folder and file and then select that one first, then you can delete the one you don't want.
    The issue is it starts loading a file when you select it but don't play it, so I leaves an open handle to the file leaving you unable to delete it....
  3. #383
    Jan 2018
    Azerbaijan, Baku
    I tried to play media from USB flash card in order to not make a HDD active and delete the folder, did not work. Tried to play a file on HDD from one folder and delete another one, did not work. I even can't delete an empty folder.
    Would downgrade from 5274 to 4120 work? Shall I try this one?
  4. #384
    No that won't help.
    If you want the HDD totally blank of music you need to format the partition with a firmware cd
  5. #385
    Jan 2018
    Azerbaijan, Baku
    No that won't help.
    Ok,then as agreed I will wait for josi's format image from you. Unless you suggest any other fix...
  6. #386
    Jun 2012
    kuala lumpur
    Problem with RNS510 3C0--381B HW 004 SW2960
    Hello everybody. would like to get some experts views.
    My RNS510 381B (japan) recently died and there's no text whatso ever on the menu. Sometimes it boots (without text) and sometimes it stucks whitescreen after boot image.
    I'm trying to load the many firmwares from 5238 josi down to 1100 factory and modified as well as SWL fix. nothing works except stuck at SWL error 010306.
    Is this HDD issue? I replaced a new same HDD but still the same. Some says it's the CD/DVD quality of the firmwares but i'm not sure. seems like its something else. maybe the firmware is not right for the Japan unit? appreciate your help and views. tq.
  7. #387
    Quote Originally Posted by benzinkopf View Post
    You need Japanese firmware.
    Can't help you with locating that unfortunately.
  8. #388
    Oct 2018
    Porto, Portugal
    kamold the host provide for you it open but it doesnt work i dont know why.
    i sended you a private mensage
    I have a volkswagen passat cc rns 510 i changed the HDD to SSD 64gb.
    1T0035680B
    Could you send me a link to uploud fw 3810 version 65/35/5 as you done please or other ratio that fits the maps on the SSD please
  9. #389
    Apr 2019
    UK
    Hello,
    I have a SII from 2014 with a H21 Columbus 3T0 035 686 H. I upgraded from 6270 to 6276 when I got the car a few years ago. Now the Western Europe map v16 will not install anymore. My feeling is that the problem is the partition size. I am wondering whether I can use a downgrade to FW 4120 with a Europe partitioning which I found on this site and then upgrade again to 6276.
    Or alternatively are there any "custom" FW with a larger map partition?
  10. #390
    Apr 2019
    UK
    If you are in the UK then you'll need a large map partition.
    I have an upgrade for 6276, but with a small map partition (for Aus/NZ). I don't have access to my tools I need to build a new one at the moment, but there are firmware images available that will just do a format of the partitions, just may need to enable firmware downgrade.
    Let us know if you are still having problems and I'll try and sort something out for you.
    Hello kamold,
    Reading through your post from a 2016 you mention a format of partitions. Would formatting the partitions also enable me to change sizes?
    Does anyone have a link to RNS510 HDD formatting software please?
