Page 38 of 41 FirstFirst ... 283637383940 ... LastLast
Results 371 to 380 of 404
Thread: Firmware updates for European RNS510 units
  1. #371
    Thanks for updating the thread. It helps others if they have a similar issue
  2. #372
    Feb 2017
    TM, Romania
    Hi guys,
    Coming back to you with another issue. I am unable to pair my Iphone 6s with the Phaeton's bluetooth. Infotainment SW and HW versions from VCDS:
    Mileage: Repair Order: NAVI
    Address 37: Navigation Labels: None
    Control Module Part Number: 3D0 035 680 HW: 3D0 035 680
    Component and/or Version: RNS-MID H10 0204
    Software Coding: 06050000000000220020
    Work Shop Code: WSC 76112 146 188510
    VCID: DDB1FFFFC4C4D5F65F5-8088
    After searches I came up with the conclusion that it can be done only by updating the bluetooth module to a newer version (gp3) or an aftermarket one. Anyone with experience in this matter? Dealership said iOS devices can't be connected because of apple's rights over their proprietary bluetooth technology and that VW, until 2011, didn't buy them.
    Thanks,
    Bogdan.
  3. #373
    What is the part number of the Bluetooth module?
  4. #374
    Feb 2017
    TM, Romania
    I can't find bluetooth module, only telephone:
    Address 77: Telephone Labels: None
    Part No SW: 3D0 035 385 A HW: 3D0 035 385 A
    Component: J412 8605
    Revision: 00016000 Serial number: 0000B7A118052
    Coding: 0020141
    Shop #: WSC 01065 000 00000
    VCID: 204F060BF336381EB43-8075
    No fault code found.
    If you know the address of bluetooth, I can scan it.
  5. #375
    That is the Bluetooth module.
    Try and see if there is an adaptations channel for factory reset or delete profile.
    Remove all profiles and try and pair it.
    What is the error on the phone and on the MFD when pairing?
  6. #376
    Feb 2017
    TM, Romania
    Only way to pair it is for my car to search for devices, it finds my iphone and when trying to pair I get "Device is not compatible".
  7. #377
    Don't know anything specifically about the Phaeton but I'd guess you need to get a 9w7 Bluetooth module to replace your current unit.
  8. #378
    Feb 2017
    TM, Romania
    I got in touch with the guys from ross-tech but they replied:
    "What does ALL of the writing say on the part that plugs into the car?
    Please send detailed photos of the interface cable including any stickers on it."
    Do you know what part should I be looking for? Bluetooth module probably. Any ideas where is it located in the Phantom?
  9. #379
    In most other cars it is under the driver's seat.
  10. #380
    NSW
    - Deleted post -
