Page 34 of 41 FirstFirst ... 243233343536 ... LastLast
Results 331 to 340 of 404
Thread: Firmware updates for European RNS510 units
  1. #331
    Yes 5238 is the way to go. No coding will be lost.
    Sent from my HTC One_M8 using Tapatalk
  2. #332
    Mar 2016
    France
    thank you,
    All newer firmware are not compatible ?
  3. #333
    Quote Originally Posted by jimbo4215 View Post
    thank you,
    No. Only for newer units.
  4. #334
    Mar 2016
    UK
    Hope someone can help.
    MY Unit is Rns 510, 1T0 035 680 R, 40GB Sd Drive, C14, Hardware H27, Firmware 6276, Map upgraded to V13.
    After some research and looking at firmware file scripts, looks like drive is corrupt and needs reformatting or replacing but FW 6276 only updates existing files, looks like I need firmware 62xx that does a new install with a disk format of 3 partitions.
    Any assistance much appreciated.
  5. #335
    Quote Originally Posted by Bartok View Post
    If you are in the UK then you'll need a large map partition.
    I have an upgrade for 6276, but with a small map partition (for Aus/NZ). I don't have access to my tools I need to build a new one at the moment, but there are firmware images available that will just do a format of the partitions, just may need to enable firmware downgrade.
    Let us know if you are still having problems and I'll try and sort something out for you.
  6. #336
    Apr 2016
    U.K.
    Hi guys
    Looking for some advice, after searching I came across the solution to my boot loop problem and upgraded to firmware version 4020.
    Can I upgrade to a later version? The details on my unit are:
    Model: 1T0035680D (was B before update)
    HW:11
    SW:4020
    Also I noticed that I don't have POIs anymore do I need to do a downgrade to a lower version to get the partitions then go to the later version?
    Thanks in advance for your help
  7. #337
    Use 5238. If your pois have been deleted you need to reload them.
  8. #338
    Apr 2016
    U.K.
    Thanks for the quick reply!
    Should the POI be on the maps DVD?
  9. #339
    There are pois integrated into the maps DVD however for personal pois you need to install via SD card.
  10. #340
    Jun 2014
    Holland
    I can confirm that the 5238 firmware works fine on my 1T0 035 680 B HW:H11 RNS 510. I previously had the 4020 firmware from this forum on it and the upgrade to 5238 went fine. It now reports a delivery part nr 1T0 035 680 L which previously was D.
