awesome, you're a legend. Ill be in contact once this arrives.
It's got the correct European firmware, just every time I try and install the v9 maps the device keeps restarting. I'm going back to v8 maps for now
Give me a day to get the image built and uploaded if you would like to test.
Sent from my HTC One using Tapatalk 2
HELP!
I'm new and I'm sorry if this has been asked before . . . . .
I have a lovely 2009 passat CC and would not change it for the world! However I have just purchased v9 maps that I plan on installing as some of the roads I travel are completely different to those stated in the current version of maps (v4). I have a few questions:
Is it possible to understand what the difference is between these map versions? Or is it a simple act of hoping the update you require is in the updated version?
And secondly . . FIRMWARE! . . . . I dont know what version my current RNS510 firmware is (i dont actually care), I dont have access to the secret menu (apart from the AM FM & DAB options), and I believe the firmware has not changed since its birth April 2009. But I would like to understand is there any information about what each firmware version includes?
Also why would I want to update the firmware? What are the reasons etc
The only thing I dont like about the RNS510 is perhaps its a little slow to respond to touches? perhaps?
Firstly this is an Australian forum and our maps are version V6 Our modified firmware is different to what you would use in Europe as well.
We do not have DAB as ours is different is called DAB+
Firmware updates bugs and gives different features like extra voices and should make the unit run better.
The Euro maps are bigger and our modified partitions of 90/5/5 don't work on your units.
Wait for Kamold to answer he may have a version you can use
There is no published map change list from VW. You would need to get in touch with the GIS map data provider for the UK, not sure who that is.
If you don't care what firmware version you have then don't update it. Updating will give some new features such as RDS, additional male voice for guidance and some speed increases in the UI and navigation. It can't make it as fast as a newer unit which has newer hardware however.
