Page 5 of 41 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 404
Thread: Firmware updates for European RNS510 units
  1. #41
    Apr 2012
    Czech Republic
    Quote Originally Posted by jamerson View Post
    i am uploading the 4020 for Unite A/B/C for Europe users
    will share the links soon and please update the first link!
    edite
    please add to the first post this 4020 for Unite A and B and C with European Partition
    I installed this fw on my RNS, previous Version was 2760. The update was successfully finished, but after the reboot the harddisc partition was unchanged, there were still all my MP3s and navigation maps. So I think, there is a little mistake in this firmware.
  2. #42
    Apr 2012
    Germany
    Quote Originally Posted by kundatra View Post
    i installed this too, but somehow can't get the POI working, and also the speed limite is not working,
    so i will go back to Firmware 3810 which worked fine but no POI, still looking for solution will share while i have solution,
  3. #43
    Apr 2012
    Czech Republic
    Do you have after installing of 3810 three partitions in your RNS? Maybe you have only 2 - one for media and the second for maps. That maybe why your POIs doesn't work.
    I tried your 3810ANORU-M3-EU.iso firmware too, but this image doesn't boot in my RNS. I tried another - standard image of fw 3810 with standard drive partitioning 50/25/25 and after that I apllied 4020 for Unite A and B and C. Now ewerything is working, incl. POI - POI uses the third partition for correct functionality.
  4. #44
    Apr 2012
    Germany
    i applied the same firmware somehow can't get the POI working,
    are you able to see the speed on the map while driving?
    what is the extention of your POI?
    PersonalPOI.db3 or POI.db3?
    the firmware 3810 has 3 Partition i modife it my self, i am sure is not the Partition but the way how the firmware sees the POI!
  5. #45
    Apr 2012
    Czech Republic
    Try to copy PersonalPOI.db3 file into PersonalPOI folder on your SD card.
    Then start the import of POIs to your RNS (it must be done manually).
    You don't have your POIs in menu of yours RNS or zou have them, but they are not visible on your map?
  6. #46
    Apr 2012
    Germany
    after i imported the PersonalPOi it told me succecefully imported, but when i go and back it ask agai to import them,
    when i go to navigate i dont see POI and also can't find POI on System/Map/POI
    4020 sees PersonalPOI.DB3 allow to import them but not to selecte them ( so not working)
    3810 doesnt see PersonalPOI.DB3 neither EDP/POI.db3( so dont know which formate does it read)
    conculusion both are not working for POI unless devoloper can advise
  7. #47
    May 2011
    Greece
    I installed fw 4020 original and the 4020 with 90/5/5 partitions with success in my RNS B but couldn't install the maps because there is no space in HDD. Then I tryed the 75/20/5 one but the iso could not load (DVD-error). I have use different media, burners, MacOS X, Windows 7, downgrade option, reset memory, downgrade to 2760 but no luck. Then I tryed the new one jamerson upload but there is no new partition map in there. Can someone upload a good 75/20/5 iso (like the 90/5/5 with VIM enabled) please. Thank you
  8. #48
    Apr 2012
    Germany
    Hello !
    I read the whole thread but finally I am a little bit confused:
    - Sometimes you are revering to a partition of 75/20/5
    - Sometimes 90/5/5
    I installed at my (C8 /C9) Navi the 4020 from the first post, but partition did not change; I have 18GB space for Music...
    ...as far as I know I should have a 40GB HDD (or only 30?), anyhow this is a little bit less (or more cal. with 30GB) than 50% !??
    How big is your space for music?
    and
    Am I allowed to install the 90/5/5 Firmware in Europe??
    Greetings
    Roger
    Skoda Octavia 2011 - 2L TDI - RNS510 (0xC801 - 06)
  9. #49
    Apr 2012
    Czech Republic
    I think, that 4020 for Unite A/B/C doesn't change size of partitions to 75/20/5, there is something wrong.
    I had version 2760, I upgraded to 4020, partition size stays 20MB/10GB. All the data remains unchanged on HDD. After downgrade to 3810 the partition was resized to 15/7.5/7.5GB, no data were found on the HDD - all was deleted. Then i upgraded back to 4020, partition size stays 15/7.5/7.5GB.
    I think, in 4020 is missing a procedure for resizing of partitions.
    Original version 4020 doesn't have this procedure too. There is this warning: "This upgrade will not create the new partitions required for the new POI system if you upgrade from 1xxx/2xxx. Upgrading from 3800-3910 is required so the new partitions are created."
    ---------- Post added at 10:41 PM ---------- Previous post was at 10:32 PM ----------
    One question: I downloaded this image from the very first post:
    Firmware 40xx - Link (thanks to jamerson) [URL="https://rapidshare.com/files/1195943676/ISO9660.rar"[/url]
    I opened the file version.txt in this ISO, there stands:
    #VwSwIndex:3810/3816/3810/3818/3814/3810/3810
    So: Is this FW 4020 image or 3810 image file?
  10. #50
    Sounds like I will have to have the ISOs created as maybe they were not built correctly. I thought that the previous instructions were clear but maybe they weren't...
    European maps are too large, you cannot use 90/5/5 ratios as there will not be enough room for the map data.
