Page 30 of 41 FirstFirst ... 20282930313240 ... LastLast
Results 291 to 300 of 404
Thread: Firmware updates for European RNS510 units
  1. #291
    Apr 2009
    I'd have to agree with FJ Steve. For older units 5238 seems to be the most stable version. I've experience nothing but problems with 5274 on B,C editions. Whereby it would go into a continuos reboot loop. 5269 seems ok, but not much benefit over the tried and tested 5238 Firmware.
    Genuine VW Parts Importer | Navigation | Bluetooth |
    Repairs | Lighting | Coding | Programming |Cameras
  2. #292
    my dads Passat CC RNS 510 is giving a SWL error
    its the same unit from factory, hasnt had any issues before.
    I think it had a software upgrade from a VW dealer a year or so back, but nothing has been done or attempted at home.
    im new to these fancy HU. from having a quick flick through here he needs to download software and burn it on to a disc im guessing?
    or is there a way to reset it without any tools?
    I see a few other people had the SWL error after updating etc, but we havent done anything like that.
    Can anyone point me in the right direction?
    Would it be easier to take it up to the local VW dealer and get them to reload the software?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  3. #293
    If it's under warranty then make it the dealers problem. If not then load 5238 firmware on there.
    Sent from my HTC One_M8 using Tapatalk
  4. #294
    thanks for that.
    out of warranty, think my parents have it up at VW to see if they can load the latest software as they have done it before
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  5. #295
    Aug 2015
    Sibiu, Romania
    I keep getting the 010306 error when trying ro install either of 4020, 4120 or 5238.
    My delivery part number and sw version currently are "-". Hw version is 04 and on the lable it says originally it was 1 Z0 035 680 A with 1004 sw version.
    The car (vw passat b7) was bought with this columbus instead of the original.
    Please help!
  6. #296
    What part of the load process does it happen? Post a screen shot of the error.
    Sent from my HTC One M8 using Tapatalk
  7. #297
    Aug 2015
    Sibiu, Romania
    It can read the CDs but before starting to install I get the below error.
    I also added two pictures, one with the present state and the other with the initial state it was before update - 2664.
    Thank you!
    Attached Thumbnails Attached Thumbnails Firmware updates for European RNS510 units-img_1607-jpg   Firmware updates for European RNS510 units-img_1608-jpg
    Firmware updates for European RNS510 units-img_1619-jpg
  8. #298
    Oct 2015
    London UK
    MK6 GOLF RNS 510 Rebooting
    Hi all,
    Basically i have a mk6 golf with a rns510 head unit, this has been working fine until weekend just gone, when you power it up the "welcome to VW" sign appears and then it just reboots, have tried a hard reset which has not made any difference at all, any idea if it could be corrupt firmware, bearing in mind it does not let me go into the menu at all?
    Thanks in advance
    Kind Regards
    Harry
  9. #299
    Yes it could be a firmware issue, could also be a number of other things.
    Try loading 5238 firmware to see if it fixes it.
  10. #300
    Quote Originally Posted by StefanG View Post
    Thank you!
    Sorry I forgot to reply to this.
    You need to try and load 5238 firmware.
    Error 010306 normally means you have tried to load too many times.
    You should be able to do a reset with setup+eject+mic buttons and then start the load process
