Page 28 of 41 FirstFirst ... 18262728293038 ... LastLast
Results 271 to 280 of 404
Thread: Firmware updates for European RNS510 units
  1. #271
    Personal POI feature was released at 3xxx series firmware. It works.
    If you load 4120 on your unit there is a chance you could damage the radio board.
  2. #272
    Feb 2015
    Den Bosch, the Netherlands
    Hello Kamold,
    I've got:
    Delivery part number: 3T0035680A
    HW version: H11
    SW version: 1304
    HW vehicle: 0xC201
    HW radio: 0004
    I tried to update the maps to V12 Western Europe but that failed and now I got no maps installed at all. I suppose it failed because (as I learned later) I have only two partitions and not enough space for the new maps.
    From what I read here I get the impression I should install firmware 4020 and can then install the V12 maps, is that right?
    And if so, can I install 4020 directly or should I first upgrade to some 27xx version?
    2009 Skoda Octavia Combi 1.8 TSI DSG
  3. #273
    What firmware version are you running? Is it one with custom hdd partition ratios? If so is it one for Europe? You may not have enough space for the maps if you have changed from the default settings.
  4. #274
    Feb 2015
    I live in Europe and just bought the car second hand there. I did not change the firmware or partitioning, so I suppose the firmware is the original 1304 and the partitioning will likely also be original (don't know how to verify this).
  5. #275
    Even with original firmware you can load New maps, the space for maps is less with 3 partitions, not more. If the load failed it's probably a bad map disk.
  6. #276
    Mar 2015
    Grubbenvorst
    Hello Kamold,
    I have an RNS510:
    Part number: 3T0035680A
    HW ver: H42
    SW ver: 2724
    Can I update to firmware 4120?
    Thanks, Rob
  7. #277
    Yes you can
  8. #278
    Mar 2015
    Grubbenvorst
    Great, thanks for your fast reply!
  9. #279
    May 2015
    Netherlands
    Hi Kamold,
    Can you please help me? I have read this entire thread and googled a lot. But I'm not entirely sure to which version I need to update.
    I'm thinking first to version 3810. But not sure which 3810 I need to pick. The normal one or the Update Modified (Regensburg syndrome, MP3 VBR Resume for revision A, B and C head units)?
    And after 3810 to 402x from this thread.
    Is this correct?
    Thanks in advance!
    1T0 035 680 B
    HW H03
    SW 0900
    Europe
  10. #280
    Just load 5238.
