Page 27 of 41 FirstFirst ... 17252627282937 ... LastLast
Results 261 to 270 of 404
Thread: Firmware updates for European RNS510 units
  1. #261
    Pacific Paradise QLD
    Quote Originally Posted by festeret View Post
    Thanks for your rapid response !
    Sorry to be heavy, but I would like you to confirm that I definitely can not install 5238.
    These are the details of my RNS 510:
    HW Version H74
    SW 4020
    HW Vehicle 0xC001
    HW Radio 0003
    SW Radio EUR_CHN_1300
    Are there noticeable differences between 4020 and 5238?
    Thanks again.
    Jorge (Spain)
    See reply 252
  2. #262
    May 2012
    Alcoy - Spain
    I've seen the reply 252, thanks.
    I just wanted confirmation when I have showed my RNS 510 data.
    Are there differences between 4020 and 5238? Only DAB?
    Thank you.
    Jorge.
    See reply 252
  3. #263
    There is only risk, not reward. There may be a modified 5238 firmware version from josi on the vwnavi forums. But there is no feature gain over the previous generation unless you have DAB hardware.
  4. #264
    Estonia
    Hello,kamold
    3T0035680B
    hw: H11
    Radio 004
    sw 4024
    map v11 8129
    what is the last usable firmware?
  5. #265
    You already are running the best for your unit.
  6. #266
    Estonia
    i think it's is no best, after installing 4024 unit not start so fast like before (3xxx)
  7. #267
    Then load the previous version.
  8. #268
    Estonia
    the previous version not have poi loading section, can i use 4120, maybe this is faster
  9. #269
    3xxx has support for POIs.
  10. #270
    Estonia
    3xxx not have this menu i cant load pois from sd card , can i use 4120 or not
