Page 21 of 41 FirstFirst ... 11192021222331 ... LastLast
Results 201 to 210 of 404
Thread: Firmware updates for European RNS510 units
  1. #201
    Or what about removing the hard drive from the rns510, putting it into the computer and copying across?
  2. #202
    The maps partition is not a format that you can access from a computer.
    You need to use the DVD drive. If the DVD drive is broken you'll need to replace it.
  3. #203
    Jul 2010
    Quote Originally Posted by rhinopower View Post
    If only it were that easy to remove the hdd!!
    As Kamold already stated - won't help.
  4. #204
    Pacific Paradise QLD
    As you have to completely disassemble the 510 to get the HDD out it might be a mission.
    If you want to try this thread shows how Have fun
    RNS-510 HDD replacement/SSD swap DIY
    Would be easier and possibly cheaper to buy a new DVD drive especially if you damage something
  5. #205
    I simply wanted to avoid having to buy a box of DL discs when I only need one, £20 is cheapest I've seen. I'd load v8 maps without poi's if I could find a reliable link.
  6. #206
    You could always buy a genuine version of the map which would probably cost a bit more than 20 pound.
    You are in the wrong country I bought a 10 pack of D/L dvd's for $19 and thought that was expensive
  7. #207
    Bought some discs and burned v9 maps. I installed v8 maps the other night but with the v9 it appears to be hanging, and if you press eject the status bar is not increasing. What am i doing wrong?
  8. #208
    We only have Aus V6 so dont know. I see you upgraded to 4120 Just DONT USE THE AUSTRALIAN version as the map partition is too small for European maps
    Maybe thats your problem.
  9. #209
    Jul 2013
    Wrong thread, I should have looked in the Australian one
  10. #210
    Re: Firmware updates for European RNS510 units
    It will likely come with 5238.
    Sent from my HTC One using Tapatalk 2
