Hello,
upgraded to 4120 successfull ! I'm transferring the maps ! Do you have the change log ? I move from 2720 to 4120 firmare. What the most important news features ?
Refer to this list for main features.
4120 adds RDS support and male navigation voice (at least for English language, not sure about other languages).
i am EU User on C device, and want to use 412x FW,
what are the features? do i still need the map disk?
See the post immediately above yours....
If you are repartitioning the hard drive you need the map disk. So if the current firmware is 2xxx series then the hdd partitions will change.
And if you are loading a custom firmware with modified partition ratios the hdd will be wiped also.
So you need to have the map disk on hand for the upgrade.
After installing the firmware, is it possible to load the new maps via sd card?
