Page 2 of 41 FirstFirst 123412 ... LastLast
Results 11 to 20 of 404
Thread: Firmware updates for European RNS510 units
    The ratio is 75% for music, 20% for maps and 5% for POI database.
    Size of each depends on hdd size.
    Apr 2012
    Germany
    thank you mate,
    first ISO is ready i am working on the second one,
    Nice one.
    If you can post the links I will update the guide to just include the ISOs rather than instructions for how to create them.
    Apr 2012
    Germany
    Nice one.
    created the ISO and burn it on CD,
    now its on the black screen,
    software download, source activated, searching for SWL,
    its like 2 hrs searching,
    probably because i am on the same firmware? i enabled downlgrand but still the same
    any suggestions please?
    Quote Originally Posted by jamerson View Post
    It is having trouble reading the disk. Try another disk. Burn at lowest speed.
    Apr 2012
    Germany
    do i need to downgrand first or not?
    i burned it at x8 and x4 speed,i lost like 20 CDs
    CD-R,
    i am already on the same firmware,
    You should not need to downgrade first, you just need to enable downgrade in the hidden menu.
    There may be a problem with the ISO that you have created.
    I will try and find some time later to make and upload the ISO..
    Apr 2012
    Germany
    i used Daemon tool, i just deleted the file and replaced the one you uploaded for me and i saved the ISO,
    One thing I have noticed at 402x firmware is the unit seems even MORE picky about CDs.
    I never had any issues with mine in the past but after upgrade to 402x I had to use xpcdburner and track at once recording to get a custom boot screen CD to be accepted.
    Maybe its worth doing a downgrade to 276x first and then upgrade to 402x....
    Dec 2006
    Kilsyth, VIC
    Is it the burner or the media or the application used to burn??
    I burnt mine using disk utility on a Mac on max speed (24x in this case) and Verbatim media and it worked fine first time.
    On a side note, For people using windows I highly recommend imgburn, it's free, simple and awesome!
