Page 17 of 41 FirstFirst ... 7151617181927 ... LastLast
Results 161 to 170 of 404
Thread: Firmware updates for European RNS510 units
  1. #161
    Any ideas kamold? I tried the load once more, leaving the engine running the whole way through for good measure, and to see what would happen. Everything seemed to go perfectly fine.. each component updated 100% ending in SWL Success. But clearly not as the partitions are still the same, and music and maps are still there :/
    I've noticed that the 'Version.txt' does not contain VwSwPartNumber: 1T0035680H. Would this cause any problems?
    MK2 Leon FR | Candy White | BTCC | New Injectors | DPF Delete | VW RNS510 | VCDS
  2. #162
    As I mentioned I'll need to check into the script file which controls the partitioning.
    The file is protected by a CRC mechanism and a special cable and software is required to generate this.
    I don't have the cable at the moment so will need to wait for a fellow forum member who has it. He is a busy man so please be patient.
  3. #163
    Okay no worries, thanks for your help.
  4. #164
    Jun 2012
    Germany
    No difference only software.
    You need the map DVD.
    Sent using electrickery
    no Software
    1T0 035 680 F with Map 7551
    1T0 035 680 H with Map 7690
    for West
    and for East
    1T0 035 680 G with Map 7552
    1T0 035 680 J with Map 7691
  5. #165
    Jul 2012
    Czech Republic
    Hello,
    i have RNS 510 with these parameters:
    1T0035680B
    HW VERSION H04
    SW VERSION 1120
    SV SW-VERSION C_EU_7.112_t1010
    HW VEHICLE 0xC201
    I read all previous posts and I think that i can make upgrade to 402x modified firmware. It's OK?
    But I dont know if I must then make coding my units. Can you tell me please if it will work (parking sensors, multifunction steering wheel etc.) without coding?
    Thank you very much
  6. #166
    Jun 2012
    Germany
    the 4020 from web are too many fakes. prefere the 3980, they are better
  7. #167
    Quote Originally Posted by lukasde View Post
    Hello,
    1T0035680B
    HW VERSION H04
    SW VERSION 1120
    HW VEHICLE 0xC201
    Thank you very much
    You should probably use 3980 firmware modified for older units. There is 4020 firmware with tables swapped available however I don't know of a public source at the moment.
    You will not need to change any coding, this is not affected by firmeware upgrade.
  8. #168
    Jul 2012
    Czech Republic
    Hi,
    thanks for reply. Please can you tell me why I can't use 4020 modified firmware? I can't find 3980 modified firmware for older units.
  9. #169
    You can use either 3908 or 4020, as long as it has been modified for older units.
  10. #170
    Jun 2012
    Germany
    1T0035680B is a C6 Version and look in the FW 3980 . you dont have any problems
    #CD 0 0 5 . 3 3 4 . 3 0 1
    #DATE:2011-06-09
    #Project: VWRNS
    #Author: RoNe
    #Steckbrief: C_EU_10.344_t191 C10/C6
    #CommentStart:
    This is a SWL CD for VW delivery.
    #CommentEnd:
    #Integrationphase: Delivery cw22/11 C10/C6-samples
    #VwSwPartNumber:1T0035680D/1T0035680D/3T0035680B/7F0035680A/7E0035680A/1T0035680F/1T0035680G/3T0035680C/3T0035680D
    #VwSwIndex:3980/3986/3988/3984
    #AppsBuild:C_EU_10.344_t191 C10/C6
