Page 15 of 41 FirstFirst ... 5131415161725 ... LastLast
Results 141 to 150 of 404
Thread: Firmware updates for European RNS510 units
  1. #141
    You express yourself very well in English, no problems there
    It is possible to change the partition ratios, but we need to generate a file that will produce the exact same CRC as is expected by the factory CD, so need special software and hardware dongle. I don't have it at the moment, another forum user has it so will ask him to create the dlscript.txt file that is needed. Then you can insert it into the ISO (and also an edited .WSH file) and have ratios of 70/25/5.
  2. #142
    May 2012
    France
    Hello,
    I find this : https://docs.google.com/open?id=0Bzn...E5uYjVPZ3VrdWc
    This firmware image file have been modified to use a custom partition scheme 65/30/5. It is specially designed for 30 Go HDD for European map data. Testmode menu have been enabled.
    I don't know if it works...
  3. #143
    One way to find out...give it a try.
  4. #144
    May 2012
    France
    Regrettably I cannot make the test. I have a hard disk of 40 GO and for this HDD the scheme 70/25/5 is better.
    My RNS510 (HW52 / FW2840 - 1T0 035 680 C) have a HDD with 3 partitions, and this firmware does not format a disk which has already 3 partitions.
  5. #145
    Jun 2012
    Melbourne, VIC
    Quote Originally Posted by Onoret View Post
    Hello,
    Obviously it does not work. Seems like someone just modified partition sheme, but did not know how to update CRC. I tried it on my C unit.
    I have 30GB hdd and I need to put both East Europe and West Europe maps. So I definitely need 65/30/5. Could someone do the file and crc?
    MY09 GTI (US spec), grey, 18" Detroit's, HID xenons, Euro LED taillights, sunroof, RNS-510 Euro
  6. #146
    Jun 2012
    Portugal
    hi,
    first of all sorry for my bad English
    this is my first post in this great forum
    I read a lot of posts to look for information how to enable the tv button in a RNS510 without an interface, it seems possible with changing the firmware. Do anyone know where can I find the firmware source code? I would like to analyze it to see if we can enable the tv.
    Thank you and a great work
  7. #147
    Jun 2012
    Bywong NSW
    I just upgraded my 510 running 3970 where I have 15GB available music space to 4020 using FW_4020_a_70_25_5.ISO and I am generally happy as it seems faster, well as fast as I would expect. The odd thing is that it has repartitioned my drive and I now have just shy of 28GB of music space on offer. I assumed it wouldn't repartition and also because I thought my drive was 30GB not 40GB. I loaded my maps (v5) no problem and I guess it went to the 10GB partition (25%) and the 2GB (5%) must be for the POI. Can someone just confirm my calulations are correct pls? Also, what is the difference between the FW_4020_a_70_25_5 and the FW_4020? Is it that the "a" is for the A hardware and the rest is the partitioning? Anyhow, thanks. I have noticed it likes to start on the radio, but think a reboot might fix it.
  8. #148
    Quote Originally Posted by brookes2622 View Post
    You're in the wrong thread...you should be using the Aus/NZ firmware upgrade.
    That will give you 90/5/5 partition ratios which will free up a lot of space for music. 70/25/5 is for Europe where their map data is much larger.
    Thats the only difference. And yes it will repartition, it was designed to do that...
    And yes the a is for older units that need some changes for compatibility.
  9. #149
    Quote Originally Posted by golf6 View Post
    hi,
    You cannot enable TV just with a firmware update. You need the actual TV tuner which is another device.
  10. #150
    Jun 2012
    Bywong NSW
    My bad. Sorry.
