Page 12 of 41 FirstFirst ... 2101112131422 ... LastLast
Results 111 to 120 of 404
Thread: Firmware updates for European RNS510 units
  1. #111
    Apr 2012
    Germany
    Might be worth just trying a cd lens cleaner and see if that helps
    i just did no result sorry!
  2. #112
    May 2012
    Netherlands
    Hi,
    After some challanges to get 4020 loaded on my RNS510, I switched computer and burned the 5th DVD. This solved my error not beeing able to upgrade
    Intitaly i seems all is fine but today I discoverd that my boardcomputer is not showing the navagation and radio anymore (perhaps I mis more).
    Any idea how to fix this?
    Thanks for your advice.
    HW Vehicle: 0xC801
    HW version: H55
    HW radio: 0006
  3. #113
    Apr 2012
    Stockholm
    Quote Originally Posted by sergiommms View Post
    You´re the only one to have done it right now.
    Strange.
    (every EU user has been having problems when installing the maps)
    I totally agree with you, that is strange.
    Maps are burned to a Verbatim DVD+R DL (Dual Layer).
    I think I used PowerISO and low speed (2x or 4x).
    Can't really remember because I made the copy in February.
    The DVD drive I have used is a Sony/Optiarc AD-7200S
    How I loaded the maps:
    Just unlocked the car and kept the keys in my pocket
    Started the unit
    Made a Soft reset (left arrow+right arrow+eject)
    Let the unit boot again
    Just pressed the "Map" button on the RNS unit
    Message popped up "Insert Navigation DVD..."
    Put in my Navigation disc
    Map were shown on the unit
    Pressed Eject
    Message shown that told me that Nav Data was being loaded to HDD.
    And now I saw the progress bar.
    After about 30min the unit turns of (probably for battery saving)
    I kept an eye on the unit all the time and just turn it straight back on again.
    After approx 50min the copying of the files was done and I ejected the disc and took the car for a test ride!
  4. #114
    We know that at 402x the units seem to be more sensitive to 'good' media.
    I am thinking that it might be worthwhile creating a 381x firmware with 70/25/5 partition sizes to load. Then if that works, you will be able to load 402x firmware without having to reload the maps...
  5. #115
    Apr 2012
    Germany
    just for curiousity
    is this Fix for old CAN gateways a firmware or just a fix for Vuci?
    is this fix my accu issue from time to time is empty!
  6. #116
    Sorry I don't understand the question...if you have questions about the table swaps you're best off asking josi on vwnavi forums as he has done them with knowledge of how and why.
  7. #117
    May 2012
    Netherlands
    Would be great to understand if others have issues with the BC after upgrade to 4020 as well.
    An solution would be even more appriciated. On a dutch Navigation forum a similar problem is reported.
    NavigatieForum • Bekijkt onderwerp - RNS 510 "update
  8. #118
    Apr 2012
    Germany
    sorry i meant Josi made ISO calls This fix for Old Can Gateways
    so my question was of this one FW or just update for VUCI,
    already asked Josi but somehow he is busy , so thought someone may knows ,
    thank you
  9. #119
    Apr 2012
    Germany
    Hello RNS-Friends,
    I have made a stupid failure with my RNS 3T0035680C (0xC801). I don't know why but I am collecting almost every SW Version for the RNS, and now something happens what never should happens:
    I updated my EU Navi with the AUS FW4020 (90/5/5) !
    Guess what is the problem: The Map will be not stored to the HDD anymore...
    Every trial, to bring back the old partition failed. The EU 3970 and 4020 from the first page here change nothing,
    2660, 2760x (special FW by Joshi for Format) and the 3810 are not starting: "SW-Error".
    Mistake in burning CD I exclude, as the CD's were already older, or already used for updates and/or burned as ever.
    What can I do ?
    Is there any trick to force the RNS for new format/partion ??
    Thank you for your answers in advance,
    ROGER
    Skoda Octavia 2011 - 2L TDI - RNS510 (0xC801 - 06)
  10. #120
    Apr 2012
    Czech Republic
    You have to enable the downgrade fw function.
    http://www.vwwatercooled.org.au/foru...ade-60666.html
    Or this guide can help you http://rapidshare.com/files/42566320...FAQ_V5_0_A.pdf
    Page Nr 13 and 17
